damaged hayame coilover... still rideable?
OMNES AD UNUM
this came off an 03 coupe after an accident @ 25-35mph ish.
this is the right-front hayame coilover. the photos are AFTER the fix and not before. the insurance shop repaired it so i dont know if their work is good or not. btw, i did purchase these off a seller on the forums, so my car is still in perfect condition currently on skunk2 coilovers. but my questions are:
1) are these still rideable?
2) what can i expect and not expect from this?
3) whats your opinion/thoughts/comments about this repaired coilover?
any help will do, im still deciding if i should or should not take the risk installing this in my car still
so if you hayame pros out their can help a fellow 7thgener, i really appriceate it
Thanks,
Tommy
Thanks,
Tommy
The part that attaches to the tie rods does not look so good. What you can expect is improper steering from the looks of it.
My thoughts are you can sell it for parts (the spring) or junk it.
The Standard One
LOL whew good thing you decided not to put them back on the car, i thought i would have to go crazy on you... yeah hopefully mike at urban can work something out for you. if not as gary said just sell them to someone who might want an extra set of shocks.
OMNES AD UNUM
i just found out my other front hayame coilover has a problem..
where the tie-rod connects (the circle gap) theirs a small crack around the circle. its about 180 degrees around and like a 1mm crack gap. for sure its not the paint that cracked but also the weld itself.
this is NOT the front-left coilover, i just took the right one to try to describe it the best i can. but this is pretty much the same as the left one but the wrench lookalike thing pops out the other side.
Hutch1051
Sep 29, 2015 09:20 AM
Islesfan
Sep 29, 2015 03:42 AM
Elciteeve
Sep 28, 2015 12:40 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
