Will Neuspeed Bar Fit ?
Old Jun 4, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
I have a '01 Sedan and would like to know if the Neuspeed Front Upper Strut Bar will fit without modifications ? I have searched the forum and it seems there's only talk about bending the Clutch reservoir bracket a little. It seems that on the JDM versions of the sedans(which is mine), there's a vacuum pipe going behind the stock air filter box which leads from the intake manifold to the brake booster pump. The Neuspeed Bar will be squashing this pipe as it crosses(left strut tower to right strut tower) near to the firewall. Anyone with this problem ? How did you go about fixing this ? Thanks.
Old Jun 4, 2004
robbclark1's Avatar
Retired suspension supermod.
why would it be any different? It should fit. Just wiggle the clutch res. and you should be fine.
Old Jun 4, 2004
zen_master's Avatar
damn, i've been looking at that clutch rev....and im wondering...and wondering....how in the hell to move that bottle..
anyway, i saw many pics in the member's ride....it's strange...on some pics, it's gone....some are twisted or bent, etc....but some are completely gone..
where are they?
Old Jun 4, 2004
gh0st's Avatar
TAQUITOS!!!!
depends on your year. the instructions said for 2001's you have to move it. and for 2002's and up you simply have to bend it forward. choose your year.
Old Jun 4, 2004
dj02's Avatar
you can move it down to the next hole. or just bend it fwd. i have it on my sedan no problems what so ever.
Old Jun 4, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
I have a 2001 Coupe and all i needed to do was bend the bracket. Easy install.
Old Jun 7, 2004
HondaLuver's Avatar
Its a celebration bitches!
well on some cars there is none, because the are automatics...lol
Old Jun 7, 2004
GaryC17's Avatar
I will get the pics in when I take them to explain which hose and pipe I was referring to. Thanks.
Old Jun 7, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
I moved mine to the next hole down. Took 2 minutes.
Old Jun 7, 2004
zen_master's Avatar
fawk, i forgot...some are auto..
can you take a pic of that "next hole" ? im confused....
Old Jun 7, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
The next hole is right below the current hole holding the clutch res. I actually had a slight problem but it was taken care of by sheer force.
Old Jun 8, 2004
zen_master's Avatar
there is no such hole in my car....it's used by another tube.....big tubee...
Old Jun 8, 2004
tripledoublegs's Avatar
Euro-Spec
same here.
Well it took me 10 min cause I lost the damn screw.
Old Jun 8, 2004
zen_master's Avatar
mannn
any close up pic of that hole that ur talking about? maybe a pic of the new location for the clutch bottle?
Old Jun 11, 2004
GaryC17's Avatar
Okay here are the pictures. Notice the pipe running parallel to the firewall. This is the pipe I was referring too which migh interfere with the Neuspeed Strut Bar. Anyone fitted it with this pipe ?
ID:	30858   Click image for larger version
juror
Suspension DIY
Jul 30, 2019 03:28 AM
bmwstar98
Aug 16, 2015 02:28 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
EM_WON
Jul 22, 2015 06:49 PM
stvpagn
Jul 9, 2015 09:59 PM
