hayame preload adjust?? help
Old Jun 11, 2004
kionna's Avatar
kionna is an unknown quantity at this point
i need to know how to adjust the preload on my hayame coilovers before i take it to the shop for install..
any advise would be great.. thanks guys
Old Jun 11, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
You don't need more than an inch of preload from where the first locking begins to keep the spring still. You also might as well do this when they are on the car so you can see what suits you best. Think about it - if your ride feels too stiff you're gonna have to adjust it while it's on the car anyway.
First make sure the third (bottom) locking nut is tight or else you'll be adjusting the height. Take the first (top) locking nut and screw it up to compress the spring (preloading it). Use the second (middle) locking nut and tighten the first and second together with both spanner wrenches.
Reason why you don't need more than an inch of preload is simple - coil bind. Coil bind happens when the spring gets compressed beyond it's limits. When you add preload the car, it manipulates the car to think it is riding on stiffer spring rates but with the spring already compressed it can come closer to coil bind. No more than an inch of preload is fine. Too much could be hazardous over time because spring compression/preload has it's limits.
Old Jun 11, 2004
518's Avatar
518
518 is on a distinguished road
What I'm still thinking about is the hole that we supposedly make bigger, from 14mm to 16mm?
I'm looking at the holes on the front and I see holes which is bigger than 16mm already.
Old Jun 11, 2004
dacivic's Avatar
dacivic is an unknown quantity at this point
If you have the 03 or 04 civic you need to drill the hayame hole bigger (from 14 to 16mm)
Old Jun 11, 2004
VNlilMAN's Avatar
The Standard One
holes are bigger tha 16mm? wtf.. i know the top one is slotted but its still only 14mm
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
TheRiddicles
Sep 21, 2015 01:28 AM
