This can't possibly be good...
Old May 15, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Anyone else see whats wrong in this picture?
Name:	dsc02557 (small).jpg
Old May 15, 2004
v8eaterokv6's Avatar
i have a new home do u
i dunno the wheel looks turned a lot and maybe there is a braket missing on the right side i cant really tell.
Old May 15, 2004
Zzyzx's Avatar
Autocross Junky
are you Bending your control arm reinforcement???
Old May 15, 2004
taz757's Avatar
Looks like the tie bar is bent.
Old May 15, 2004
flotsamm's Avatar
How the hell did that happen? Good thing you had one on.. though now it looks like you need a stronger one.
Old May 15, 2004
Zzyzx's Avatar
Autocross Junky
Well when you push your car to its limits, things flex....
Old May 16, 2004
Jap-Euro Fusion
Well, um, thats a Spoon bar, which I would have thought was stronger than that. The subframe isn't bent, and thats only an RSX bar. I looked at it, thinking maybe something hit it, but it doesn't look like it. Me and my friend are looking at making our own reinforcement frame, similar to the progress one, or I'm gonna call Comptech and find out if they sell the brace bracket separate from the sway bar kit. This just pisses me off.
Old May 16, 2004
hey man whats up. that sucks man but hey u were looking good out there today a lot better than me lol. i had some major problems coming home today. i hit a major pot hole and broke my right rear strut had to drive the car about and hour with it a half inc off the gtound. looks like its time to buy some true coil overs.
Old May 17, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
This only goes to show one thing, rear lower tie bars WORK !
Old May 17, 2004
sjoback's Avatar
sjoback is an unknown quantity at this point
what kind of springs are you using?
Old May 17, 2004
PunkingCivic's Avatar
I need TP for my bunghole
I think he is running Jic Coilovers
Old May 17, 2004
Ershall's Avatar
Ershall is an unknown quantity at this point
Damn....hey, looks like you got your moneys worth.
Old May 17, 2004
Jap-Euro Fusion
They're JIC Magic, but that has no bearing in this. The only way that bar can give way is in straight compression. This has me a little worried, so its time to make my own... Solid Chrome Moly
Old May 17, 2004
Try using the neuspeed REAR LOWER TIE BAR in conjunction with a spoon bolt on type tie bar or the one you are planning to make. Just a thought.
Old May 17, 2004
sjoback's Avatar
I was just wondering in terms of spring stiffness, thinking a softer spring would allow more flex. But I remember seeing JICs had a decent rate, so scratch that idea.
I take it the spoon bar is hollow? I've never really known spoon products to, oh, whats a good way to say it... Well it's always seemed like it was more about image.
That comptech setup looks pretty swank, but even if they just sold the tie bar, $$$
Old May 18, 2004
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
Did you at leats have fun on the track?
Old May 18, 2004
Roy's Avatar
Roy
Roy is an unknown quantity at this point
The comptech sub-frame reinforcement bar alone retails at $300. This is the exact same bar that is included in the swaybar/tie bar combo. I have the part # if you still want it. The only thing i can really think of is that maybe you ran over a cone... at the right angle and speed, it is more than capable of doing damage.
Old May 18, 2004
Zzyzx's Avatar
Autocross Junky
^^ true, I've seen Bent control arms and Axels from the F125 karts after hitting cones.
Old May 18, 2004
dj02's Avatar
now that's some mad flex going on back there...and u have a rear upper strut brace to right the cusco one?...
Old May 18, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
Are you a 100% percent postive you didn't hit anything.........
Old May 18, 2004
Jap-Euro Fusion
If I hit a cone and it made it all the way back there, I think I would have heard it, and it would have showed up on the timing sheets. Since niether occured and there are no scratch marks on the bar, I think its safe to say I didn't hit anything. If I did... it more than likely wouldn't be bent straight up, it would be bent back as well.
Old May 18, 2004
Zzyzx's Avatar
Autocross Junky
well.... If you really wanted your car to last 200,000 Miles would you be autocrossing with it???
Old May 18, 2004
Jap-Euro Fusion
Need I remind you that Ron's current car has almost 223K on the clock, his old one had over 4.
And no I don't care how long it lasts, I just want it to stay in 1 piece for now.
Development of a chro-moly replacement is under way, and we're going to FEA it first.
Old May 18, 2004
Jap-Euro Fusion
I just looked at it really close after polishing it... At somepoint, something hit the bar... but it looks like it just scraped the bottom, looks pretty old (it was corroded), and its on the other side from where the actual bend is now. Thats kind of odd, because you'd think if it got weakened, it would be where it bent. I don't know whats up. With it. The bend is completely smooth, which is better than a kink... if it kinked the bar pretty much just gave way. I wonder if it just got overstressed and is too tight. I tried relieving it a little bit by turning out the threaded end a turn, we'll see if it straightens it self back out. This seems a little odd to me, but we'll see what happens. Even if it rights itself, I'm still making one without a threaded rod end.
Old May 18, 2004
Zzyzx's Avatar
Autocross Junky
I'd replace it rather then see if it straightens out. Biggest issue with aluminum as a structural part, every time it flexes it cracks. So every time it bends it gets weaker.
Old May 18, 2004
Jap-Euro Fusion
I'm making 2 of them. 1 Temporary one that reuses the Spoon Endplates, but without the threaded end, and a second one that is 1 solid piece that bolts straight into the subframe, quite possibly with a direct swaybar reinforcement cradle built right in. But I need something to replace that. As soon as I have Chrome-moly and a Mill, I'm on it.
Old May 19, 2004
Snakey's Avatar
From: Edwardsburg, Elkhart, Granger, Mishawka, South Bend
Snakey is an unknown quantity at this point
Justin.... keep me posted on that new bar... and if you need any help with fittings and what not i got a hook up there too... i might consider buying one off ya if it works out well...
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
RSKtakR
25
Sep 14, 2015 07:43 PM
Wiggles
Sep 8, 2015 05:05 PM
Stock 99
Sep 5, 2015 06:06 AM
