koni yellows creaking in front
Old Apr 7, 2004
stlblues13's Avatar
stlblues13 is an unknown quantity at this point
Anyone with Konis experiencing creaking in the front when turning? I have Konis and Neuspeed Sport Springs and Strut Tower Bar and I get a loud creaking sound from the passenger side front when turning. It happens with my 17"s or the stock wheels/tires and it does not seem to matter what the weather or the load in the car.
Anyone else have this problem, or have suggestion on how to fix it?
Old Apr 7, 2004
flotsamm's Avatar
Could be the bolt that holds the insert is loose or your strut isnt indexed right is a common problem. Read this post here: http://www.7thgencivic.com/forums/sh...hreadid=148207
Old Apr 9, 2004
sstaley's Avatar
sstaley is an unknown quantity at this point
when these were put on did you use the stock dust cover? if so it could be rubbing a little causing an annoying sound.
Old Apr 10, 2004
Titleist71's Avatar
or it could be your brake indicator...which squeeks very loudly...I put new brakes on and no more annoying sound.....oh ya...I just got done putting my Konis in...just like 15 mins ago.....WHOA what a difference!!!!
Old Apr 11, 2004
Joey_Zazza's Avatar
Joey_Zazza is an unknown quantity at this point
so if you line up the dust cover better, it'll take this noise out, cause I have the same exact sound...
Old Apr 12, 2004
sstaley's Avatar
or try to find a larger one
Old Apr 12, 2004
flotsamm's Avatar
I dont think its the dust cover.. all it does is sit over the strut piston. It shouldnt come in contact with anything.
Old Apr 13, 2004
sstaley's Avatar
u r right , but if the new aftermarket strut is just a little bit bigger around, it could cause rubbing with oem parts like the dust cover. this might not be it, but i've seen it happen with teins.
sstaley
Tedverseti
Apr 23, 2020 01:45 PM
BootyDo
Jun 21, 2016 03:45 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Causemo
Jul 5, 2015 06:42 AM
