Cusco Rear Upper Strut Bar
Old Nov 12, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
So, What has to be done to make this bar fit properly? I searched I didn't really find a DIY or explanation. Will it bolt directly or will I have to modify something?
Old Nov 12, 2003
civicvtec1ps's Avatar
Search and Learn
You need to remove 1 wire cover (its useless) and then the bar fits. If you want to use the body mounts you need to epoxy or JB weld in nutserts and then you can bolt it in. The right side needs a little dremeling to get the hole open (there's some kind of bracket inside the rail blocking the hole).
But other than those 2 little things, it fits like a glove.
http://www.7thgencivic.com/forums/sh...ighlight=cusco
Search button works fine.
Old Nov 12, 2003
cwick187's Avatar
I searched, but for some reason that thread didn't come up earlier...Thanks!
Old Nov 12, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I know there's a DIY... cuz I wrote it in April when I had it imported. Search the suspension forum... it should be there.
Old Nov 12, 2003
cwick187's Avatar
Ok...Thanks so much guys
Old Nov 13, 2003
HondaLuver's Avatar
Its a celebration bitches!
i put it in and i didn't know how the hole on the right side was compleatly covered, i dont' have a a dremel, and i don't know where to get those bolts, the bolts that came with the bar don't fit in the first place...
trellex
Electrical
Jul 9, 2015 12:01 PM
Causemo
Jul 4, 2015 07:11 AM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
