Eibach Pro Kit... camber kit?
Old Oct 22, 2003
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
Question Eibach Pro Kit... camber kit?
Just wondering if I was to get the Eibach Pro Kit that lowers the car 1" front and rear, would I need to get a camber kit? At what lowering point would you need a camber kit? Thanks
Old Oct 22, 2003
civicvtec1ps's Avatar
Search and Learn
no you will not need camber kit with prokit drop. you wont ever need camber kit but i would suggest you to get one if you drop more than 1.75".
ibtl.
Old Oct 23, 2003
Majarvis's Avatar
Thanks
Old Oct 23, 2003
Majarvis's Avatar
Sorry for all the questions I'm new to suspension components. But I can just install these springs over the stock shocks, right? Or do I need to buy anything else?
Old Oct 23, 2003
Search and Learn
you can install eibach springs on stock shocks but save up for aftermarket ones , because you will need to replace them eventually.
http://www.7thgencivic.com/modules.p...Suspension+FAQ
suspension faq
Old Oct 23, 2003
Majarvis's Avatar
I've heard some people blowing their shocks in one week with the prokit(about 1")
Old Oct 23, 2003
CiViCLiZeD714's Avatar
i just got my pro kit installed...beautiful ride...sits a lil high in the back about 3 finger gap but it should settle after i put a system in...i haven't experienced any problems with the shocks
Old Oct 23, 2003
Majarvis's Avatar
Awesome, how does it feel compared to stock?
I just hope after putting them on your shocks don't blow like the FAQ said
Old Oct 23, 2003
JayFReaZy's Avatar
yea, I plan on getting the pro-kit too. I herd your shocks will be find if you drive noremally though. As long as you dont make any crazy turns or anything like that, it should still last you for a long time.
Old Oct 23, 2003
Majarvis's Avatar
Crazy turns as in... autocrossing? lol
Old Oct 23, 2003
Search and Learn
just get damn springs. you will be fine for while trust me. you will probbaly need to get new shocks eventually anyway. long as you drive carefully. drive VERY slowly at any railroad tracks, bumps. your shocks will last long. im running tein s tech springs with stock shocks. rides nice. had them for about 1000miles. stock shocks are fine . hopefully shocks will last me until i can afford to buy koni yellow or kyb (if they ever come out for god sakes)
Old Oct 23, 2003
Majarvis's Avatar
Alright, thanks.
Old Oct 23, 2003
Majarvis's Avatar
One last thing, even if I DIDN'T get the Pro Kit would the shocks require replacement eventually anyway? Or is it that by putting smaller, tenser springs on to the shock it induces more stress?
Old Oct 25, 2003
dragoon's Avatar
had prokit for a year. i've taken plenty of crazy turns, autocrossed before, tray slid, etc.
my shocks are not blown
my camber is not off
and yes, your stock shocks can blow without the aid of aftermarket springs, depending on your driving habits and road conditions.
Old Oct 25, 2003
Majarvis's Avatar
Awesome, just what I needed to know Thanks
Old Oct 28, 2003
JSlick's Avatar
JSlick is an unknown quantity at this point
Pro-kit warranted camber
I just put in the pro-kit a week or two ago. They were actually springs used for 3 or 4 months prior to me purchasing them.
On my 2002 DX coupe, I have 17 x 7 Konig Appeals wrapped in 205/45/17 kumhos.
Maybe since the pro-kit springs were already settled in, they caused noticable negative camber in the rear. Don't get me wrong, the negative camber wasn't extreme. Since the tires were brand new, I could tell that the rear wheels were riding more towards the inside of the tire rather than flat/level on the asphalt. I went ahead and bought the camber correction parts which fixed the problem while being re-aligned.
but hey, i hear some negative camber helps in cornering.
Well, just my experience.
Old Oct 28, 2003
Majarvis's Avatar
Eeek, hopefully that minor of a drop wouldn't need a camber kit Maybe it's just because you're running 17's? I dunno...
Old Oct 28, 2003
Search and Learn
you wont need camber kit lol. dragon has 17".205/40/17. he doesnt have camber kit. if you are worried. just get it.
Old Oct 28, 2003
Majarvis's Avatar
Ok thanks.
Old Nov 9, 2003
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
My experience from driving over 80,000km with Eibach Pro-Kit
- The shocks are definitely blown, but still driveable. Just bounces a lot and doesn't soak up mid-corner bumps well
- You DEFINITELY need the camber kit, for the rear. I rotate my tires every season... well, last summer, the entire tread on the inner side of my tires were gone!
Trust me, things get progressively worse... cause I doubt many of you haven't driven 80,000km lowered
Old Nov 9, 2003
Majarvis's Avatar
Eeeps! Maybe I won't lower the car then. But will the stock shocks still blow as fast as with the stock springs? I'm thinking maybe I won't lower it then since we get a lot of snow in the winter (well, so do you in Ontario) so there's really no point I guess if it's going to cause problems with tire wear...
Old Nov 9, 2003
i drive in california and i have pushed my car like crazy on left turns...the rear tends to slide out a lil but if you know your car then you can handle it...i haven't blown the shocks...atleast i think i haven't...this might sound stupid but how exactly are you supposed to know that the shocks are blown?
Old Nov 9, 2003
Majarvis's Avatar
I second that question...
Old Nov 9, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
Tojo is an unknown quantity at this point
im thinkin bout gettin prokit too this is a good topic hehe
now where shud i get my camber kits from?
i have 205/40
Old Nov 10, 2003
O1Coupe's Avatar
Well, first of all, go on the highway. Do about 70mph, then quickly do an aggressively lane change. Your car will sway--you will feel your tires turning, and it takes a second for the body of the car to catch up. Then tie in two lane changes. One over, then back in again. You will feel more roll, and more sway. It shouldn't notice excessive roll.... unlike my car.
Another way to tell is during mid-corner bumps. Take a sharp turn on an uneven road (potholes, bumps, etc). Your car is supposed to be planted down, retardless. Instead, your car will hop around. That is a sign of a shock that is worn, and isn't doing its job.
The classic mechanic way of telling, even tho not totally accurate, is to push down on your car, near the wheels. Push it down HARD, and it shoudl only bounce ONCE, then come to a complete stop. If it bounces back up, then down again, then you have blown shocks.
Old Nov 10, 2003
Majarvis's Avatar
Ok thanks!
Old Nov 13, 2003
O1Coupe's Avatar
This is how low it gets after 80,000km of lowered driving...
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
