new cusco sway bar(info)
Search and Learn
Here it is
Cusco sway bar 25mm $250 + shipping from www.napsusa.com.
same diameter as mugen sway bar but cheaper.
i got info from this thread
http://forums.clubrsx.com/showthread...hreadid=118056
i cant find cusco sway bar from that site though.oh well for now
DIY King
Hmm... It's never too late to switch.
I'de get it if I could get a bigger front sway bar too. Right now the 27mm/22mm front/back combincation is working fine for me. I'de like to have it be stiffer, but proportionally so. If there something thicker available for the front as well? If Cusco makes a thicker front sway bar too, then I might get them as a set. Otherwise I'll just stick with what I have.
I'de get it if I could get a bigger front sway bar too. Right now the 27mm/22mm front/back combincation is working fine for me. I'de like to have it be stiffer, but proportionally so. If there something thicker available for the front as well? If Cusco makes a thicker front sway bar too, then I might get them as a set. Otherwise I'll just stick with what I have. Thread Starter
Search and Learn
I'de get it if I could get a bigger front sway bar too. Right now the 27mm/22mm front/back combincation is working fine for me. I'de like to have it be stiffer, but proportionally so. If there something thicker available for the front as well? If Cusco makes a thicker front sway bar too, then I might get them as a set. Otherwise I'll just stick with what I have. DIY King
K3wl. I guess I'll have to wait for now... Maybe different sway bar mounting points will stiffen things up? Actually, yeah... That's another way to make what you have already be better. Hmm... I'll think about this one.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
muniorbust
33
Aug 31, 2015 08:59 PM
