Koni Noise
Old Oct 13, 2003
VRoomPSHeRt's Avatar
VRoomPSHeRt is an unknown quantity at this point
Koni Noise
so i got a set of konis about 2 months ago. they worked great, no problems or anything. But then a few days ago, i had a few friends in the car and i kept hearing this popping sound, as if the shocks were bumping or hitting something. And it doesnt start sounding like that until i drive for a while. I've had a full car when i juss put on the shocks, it didnt make this sound. I duno what to do cause konis are replaceaple struts, and dont have the original ones anymore. Any suggestions or comments would be helpful.
thanks
Old Oct 13, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
--> moved to suspension
Old Oct 13, 2003
CivicHX01's Avatar
be more specific... you got koni's but with what... springs or coilovers? what kind of springs or coilovers? did u install the koni's yourself? did you have a shop install them?
Old Oct 13, 2003
i have konis wiht progress springs, a 2.22 inch drop. no i didnt install the konis myself, i had a suspension shop install them for me.
Old Oct 13, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
If a clunk is being made, I'm very inclined to say it's the springs. Might want to try not so severe a drop in the rear.
Otherwise. . . hmm, is this sound in the front or rear? (Will make a HUGE difference)
If it's in the rear, they're a direct replacement. . . no cutting of the stock shock housing to insert the Koni into. If it's the front, then I'm guessing they didn't get the tophat on in the right direction.
Basically, there are arrows on both the tophat and the shock assembly for the fronts. Line them up, and the mounting angle for the fronts will be perfect. . . . don't line them up, and they'll make a noise when there's enough travel in the suspension. It's a pretty easy mistake to make, and the more I think about it, the more I'm thinking that may be all you're experiencing. . . . . IF. . . IF it's the front.
Please specify.
Old Oct 14, 2003
hey Yukonart, thanks for the info, and yes the front shocks are the ones that are makin the clump noise. so what do u htink i should do?
Old Oct 14, 2003
djmota's Avatar
another thing it might be is that the bottom bolt on the front strut insert is loose, causing the strut insert to move up and down and clunk. check both of the bottom allen style bolts that go up into the strut for tightness.
Old Oct 14, 2003
KeNsHiN's Avatar
LEVA
Yukonart did you ever have these problems? and how low was yours?
Old Oct 14, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
lol kenshin those bumps on power in OWNED YOU
Tedverseti
Apr 23, 2020 01:45 PM
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
tommycanada
Sep 5, 2015 04:59 PM
