dilemma? need advice
Old Oct 7, 2003
showoner's Avatar
showoner is an unknown quantity at this point
i want to get some opinions about suspension. i need to decide if either bags or full coilovers. i driver my **** hard daily but i also want the wow factor that air bags get. being able to lower my ****.but i got some info on bags and i would have to just be careful and be ready for **** to **** up. now im not sure if i want bags, i had an accord before and i messed with the suspension( coli overs) , but i hated the ride it gave me, all bouncy . dude i hated my ride. i was thinking of true coliovers, but i hate the fact that i will have to crank them up and down for adjustability. so i need some advice. either bags or coils. " what would you get"...
just want some feed back on this subject as i knowmanyhave thought about this. any help will be greatly appreciated thanx guys............
Old Oct 7, 2003
civicvtec1ps's Avatar
Search and Learn
airbags wont ride good as fullcoilovers. since you drive hard daily. fullcoilover is the way to go. adjusting height isnt hard with fullcoilovers. b&g seems to go lowest, compare to tein basic/ss
Old Oct 7, 2003
Zzyzx's Avatar
Autocross Junky
First off, a set of "Bags" Will not handle nearly as well as a good shock/spring combo. The most probable reason your accord was so bouncy with the coilovers was that the shocks were either blown or to weak to properly dampin the springs. If you go with a short spring or higher spring rate you need the correct shocks to control them.
Second, if your cought up in the "WOW" factor then go ahead and get the bags.....
Old Oct 7, 2003
showoner's Avatar
hey thanks for your responses , i was also thinking about it and yeah, i may as well go with full coil-overs b/c i thought about how i leave every morning doing steady 90 mph on the toll road do yeah i know i wouldnt be able to hug corners with bags...so my mind is set .thanks again for the feedback , really helps out ....
Tyler93
Mar 20, 2016 09:03 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
PunX
Sep 23, 2015 10:45 PM
sf3r8z
Sep 23, 2015 03:26 PM
bhollie
Sep 22, 2015 11:08 PM
