adjust stock shocks???
Old Oct 7, 2003
def01tones's Avatar
You bought a used dog??
def01tones will become famous soon enough
Question adjust stock shocks???
i just got my dropzone coilovers and i know they're not the best but i dont give a f*** i just got these to lower it until i can get some good ones. i was wondering if i need to do anything to the stock shocks/struts before i put them on?? imp:
Old Oct 7, 2003
djmota's Avatar
just follow the directions and cut (shorten) the rear bumpstops.
Old Oct 7, 2003
civicvtec1ps's Avatar
Search and Learn
http://www.7thgencivic.com/forums/sh...ht=diy+springs
just save up so you can buy aftermarket shocks when you need them later on
Old Oct 7, 2003
VNlilMAN's Avatar
The Standard One
just as a warning, dont drop your car too low cause i know alot of people who have blown their shocks using sleeved coilovers. i plan on getting ground controls installed but only dropping it 2" max.
if you really want to slam it tho, your going to have to cut the front perch.
Old Oct 7, 2003
def01tones's Avatar
i wanted to drop it 2"all around but if i have to cut something i dont want to screw up the car. what is the perch and what does it look like??
Old Oct 7, 2003
VNlilMAN's Avatar
The Standard One
you should be able to drop it 2" without cutting the perch...
the perch is what the spring normally sits on. since sleeved coilovers uses the threaded body and has the perch on it, you dont need the stock perch(well just a little part of it). the stock perch gets in the way of the threaded body making it hard to adjust down to like 4" so you cut it
Old Oct 7, 2003
def01tones's Avatar
cool thanks! pics before and after posted soon!
Misfit2613
Jul 30, 2015 09:49 AM
Jul 12, 2015 11:54 AM
CivicsClass101
Jul 9, 2015 11:14 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
