Another Clicking Sound Thread....
Old Sep 17, 2003
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
Exclamation Another Clicking Sound Thread....
Alright...heres the prob.....
I make a wide left hand turn...at 60km/h....or even do a uturn at like 10km/h...I hear a clicking sound...supposidly from my rear right side.....(g/f told me that's where the sound was comming from when she stuck her head out the window)....
Suspension = Koni Yellows, Ground Control Coilovers, 17inch Rims on 215\40\R17's....
Ne suggestions...on why there is a clicking sound....it goes click click click click....about that fast....as you can read it.....
Any ideas will help me find/locate the problem..and solve it...I just need a bunch of ideas....so I don't miss it..when I try to fix the problem...
Thanx for the help....
A.P
Old Sep 17, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Could be either leakage in outer CV boots or leaking struts.
Old Sep 17, 2003
djmota's Avatar
sounds like a worn cv joint to me.
Old Sep 17, 2003
NorrinRadd's Avatar
Actually, I agree w/ djmota. Your suspension looks good, if you were getting pops and clicks sporadically from bumps as well turns, then your struts might be going. I don't think that's the case, it is most likely your cv joints (if you hear constant clicking all the time then your outer and inner cv boots are cracked and leaking, causing the joints to click). Even if you stick your head out the sounds of clicking can seem to come from different directions, but I'm pretty sure it's your cv boots and/or joints. I had the same thing happen and I thought it was coming from my right side (from sounds), but was actually the left side. Hope this helps...
Old Sep 17, 2003
bimmer's Avatar
bimmer is an unknown quantity at this point
well you could always stop driving the honda and get that ducati haha
i would have to guess cv joint as well
sounds logical
Green02civic
Jul 27, 2015 10:48 PM
BootyDo
Jul 26, 2015 10:38 AM
Smokahontas123
Jul 22, 2015 10:07 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
