Koni Front Strut Install q's??
Old Aug 21, 2003
01SilverBullet's Avatar
01SilverBullet is an unknown quantity at this point
K so i got the fronts today......finally! Went to take them to the shop to see how much it would cost and everyone said they wont do it cuz you have to cut the strut(some liability BS) neways.....imma do it myself. I just wondered if anyone had any tips to watch out for or whatever. Imma put some thread lock **** on the bottom bolt so it has less of a chance to work loose like some other 7thgen member have had with their koni fronts. If you could help me out at all and let me know what is hard and what you need to look out for, that would be great. thx.
Old Aug 22, 2003
VNlilMAN's Avatar
The Standard One
use pipe cutter instead of a saw...
measure 3 times drill once...
i dunno =p
Old Aug 22, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
make sure you cut it the same length on both sides? hehe. it was hard getting the koni into the cut strut for us. we had to knock it on the ground a few times...then the arms got bent in (where the 2 bolts go into)...so we had to widen them again.. just be careful i guess. and good luck! and don't damage the adjuster!!
Old Aug 24, 2003
orso's Avatar
orso is an unknown quantity at this point
Take your time. The strut will need some pursuasion into the stock strut body. Using a saw to cut the strut will take for ever and there is no gaurante that it will be straight. GET A PIPE CUTTER. Make sure the hole in the bottom of the strut is centered perfectlly. There is no room for adjustment. With carefull measurements the rest is a breeze. Give our self a full day to do it. for the settings i am at 3/4 turn front and 1/2 in rear. Good luck!
Old Aug 25, 2003
CivicHX01's Avatar
i did mine with a hack saw (my arm was sore LOL) and the cut wasn't straight but it still worked...
to make the strut go in easier, cut a little bit more than they suggested which is what i did... i ended up cutting about 1/8 inch more than the DIY said...
as long as the 2 tabs on the side of the koni is fully inside the housing, it won't move...
also, make sure you torque the the bolt that holds the koni at the bottom to the specs that the instructions say... i didn't and the bolts almost fell off while i was driving on the road!
Fudman
Jun 2, 2015 01:26 PM
beachglass
Jun 1, 2015 08:28 PM
honda200192
May 31, 2015 05:57 PM
beachglass
May 22, 2015 09:59 PM
GH04si
Apr 15, 2015 08:13 PM
