How do you take Tie Rod End Off? (Mbow?)
Old Aug 21, 2003
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
Ive been trying to put on my Koni inserts for the last 2 weeks, and that is how long my car has been in the shop. I've run into impossible stripped bolts, unmovable tie bars, and a lot of money for repairs. Well I tore the boot pretty badly on the tie rod end, so I bought another one. I've given up on doing that koni's cuz after hours of banging on the tie rod, it still won't come off. I've tried rethreading the tie rod end with 10 mm x1.25 and 10mm x 1.50 die and they both didn't work. The tie rod is held on by that wide bolt on the end right? Standing in front of the brake caliper, what direction should I be turning it in? I've tried both counterclockwise and clockwise with vice-grips and that thing won't come off still. Can anyone tell me the direction to turn in, and any tools that can help me get it off? I read that Mbow has done it before, but he hasn't answered my PM's and I really need to fix this soon. Anyone who has taken the tie rod end off before or fixed the threads please help, I'm pretty desperate here. My car has been in the garage for 2 1/2 weeks.
Old Aug 21, 2003
Grey's Avatar
DIY King
Allright, do this... Do not take the tie rod end out of the strut assembly. Keep it in there. Now use a large monkey wrench and put it on that nut behind the tie rod end. Put some gloves on for protection 'cause you'll bang your knuckles up when the nut comes loose. It's a regular right-hand thread. Simply turn counter-clockwise. Hope this helps...
Old Aug 21, 2003
Aznnp77's Avatar
I put screw loose on it and a huge monkey wrench and one of my strongest friends, immovable object.
Old Aug 21, 2003
Grey's Avatar
DIY King
You grabbed the nut at the end of the tie rod end, right?
Old Aug 21, 2003
Alex1's Avatar
PAUSE!!!!!!!!
Sorry, but it sounds a bit funny to me.
Old Aug 21, 2003
Aznnp77's Avatar
yes I did. any advice?
Old Aug 21, 2003
VNlilMAN's Avatar
The Standard One
start working out more... naw j/m =p
Old Aug 21, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
are u using air tools? because those help loosen stuborn nuts...
Old Aug 21, 2003
flotsamm's Avatar
The tie-rod end has a locking nut like Grey said. Loosen the locking nut first by turning it clockwise a small amount. Now the tie-rod end ball joint should be lose enough to remove by turning it counter clockwise.
Old Aug 21, 2003
Aznnp77's Avatar
still no luck, and I think I'm stripping the nut behind the tie rod, thats no good. I've tried rethreading the bolt on the tie rod end to no avail. I've tried smashing the 10 mm bolt on and trying to force it on too. 7/8 of the threads on the bolt are gone and it still won't fit. Ohhh god, with my car it's always a "I've never seen anything like this before."
Old Aug 22, 2003
AirForce's Avatar
AirForce is an unknown quantity at this point
i'm retarded
Old Aug 22, 2003
flotsamm's Avatar
Even if you rounded the nut, you should be able to get a pipe wrench or vise grips around it. Maybe try putting vise grips on the rod and a big pipe wrench on the nut. Hold the vise grips and spin the nut with the pipe wrench. It shouldnt be that difficult if you have the proper leverage.
Sep 26, 2023 06:44 PM
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
alwaysloyal360
Jul 29, 2015 02:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
17
Jul 23, 2015 11:48 PM
