Quick Camber question
Old Jul 6, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
Going to be installing Tein ss suspension, with the front and reat camper kit. Does anyone know what the camber setting are for a type r civic setup? I want to have alittle more agressive setup then stock. ANy Info would be great.
Jeff
Old Jul 8, 2003
VNlilMAN's Avatar
The Standard One
why do you want to know the type r setup? its probably the same as our cars...
if you want a lil more aggresive setup do something like -.3 up front, -.8 rear
Old Jul 14, 2003
JayFReaZy's Avatar
I also have another quick question. Im planning on buying the tein s tech lowering springs which lower the front 1.3" and rear 1.4". Since its not a significant drop, would I still have to purchase a camber kit, shocks, struts, or anything like that? Or will I be able to just change the springs and run on stock?
Old Jul 14, 2003
RoadRunner's Avatar
if you lower your car any at all, you should get a camber kit
Old Jul 14, 2003
JayFReaZy's Avatar
O, ok thanks. I just thought it was like a rule of thumb only if you pass 2" will you need a camber kit. I could've sworn I remember reading somewhere on this forum that said a camber kit is not necessary unless its dropped more than 2". I just wanted to make sure though, if I really needed one or not.
Old Jul 14, 2003
Handsonme's Avatar
You don't have to get a camber kit with ANY KIND OF DROP.
It just depends on how long you want your ish to last.
The only kit that claims no camber needed is Eibach prokit.
Old Jul 14, 2003
Jeff's Avatar
The reason why I ask, Im doing my own alignmant at work and I wanted some specs to reference off of. I already know what the stock setup is, just was curious if anyone knew what the typr r civic specs were.
Jeff
Old Jul 14, 2003
Zzyzx's Avatar
Autocross Junky
you should set your camber to....
1. the type of tires you are running
2. the type of suspension you are running (Springs/shock settings)
3. the type of driving you do
4. How long you want the tires to last
Camber settings for any street car from the factory will be rather conservative (Designed for Safty and Longevity of the tires, not for performance) no matter what the car, Type R or not.
Old Jul 14, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
No kidding. . . just because it's a Type-R doesn't mean the camber adjustment is going to be any more aggressive than our cars. They're set up to run well. . . and since they're a street legal car just like our Civics, they're going to be set up as such.
Now if you're setting up a car for a specific race type, THEN you'll be having camber adjusted to better-compete. . . but this is NOT what you want for everyday driving. Your tires' inside tread edges would be worn-down in a matter of a month or less.
Old Jul 27, 2003
CIVIC2NV's Avatar
CIVIC2NV is an unknown quantity at this point
U dont need a camber kit if ure only going that low.. I have 18's eniki RPOM witht the Yokohoma paradas. 2 inch drop in the back and 1.8 inch in the front and im rollin on stock struts.. its pretty smooth ride aswell..
I have the Goldlines 2nd version
GolNat
Jan 12, 2021 09:06 PM
rman1900
21
Sep 10, 2018 04:52 PM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
