camber kit
Old Jul 4, 2003
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
camber kit
can you still use a camber kit if your tires in the back are a little tucked? or by using camber at that height will it push the tires into the fenders?? thanks
Old Jul 4, 2003
Weaponx12o's Avatar
you can still use a camber kit, but it wont be aligned to spec. you can have the people align as close to spec as possible without having it rub. you will still have negative camber though.
Old Jul 4, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
SPC makes some rear lower control arms.. check them out maybe thats what you need
"These extreme lower control arms are for Honda Civics and Acura Integras. They are designed to allow the use of wider wheel and tire combinations and solve tire-rubbing problems. Made from aircraft aluminum alloy, these arms are available in candy red, blue and silver finishes.
When teamed up with front and rear camber arms SPC Performance provides you with a complete alignment solution when lowering your later model Civic, RSX or Integra"
http://www.spcperformance.com/PerfPa...69100_400.html
Old Jul 5, 2003
sc1golfr's Avatar
well, as it is, my tires to scrape the fenders every once in a while, not a lot though, so if i put those control arms on, would it kinda pull my tires in so that i could use the camber kit?
Old Jul 5, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
if you cut away at the lip on the rear fender about an inch, and have tires that are 205-215 then you can get it back to fac spec
Old Jul 5, 2003
sc1golfr's Avatar
yeah my tires are 215-45-17 and thats why they rub
Old Jul 5, 2003
sc1golfr's Avatar
with these rear lower control arms, do you still need a camber kit? also, say you do, does it have to be an SPC camber kit? thanks a lot.
Old Jul 5, 2003
brents1's Avatar
brents1 is an unknown quantity at this point
hey where's hilliard, ohio? Anywhere close to dayton?
Old Jul 5, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
How much are you lowered??
Old Jul 6, 2003
sc1golfr's Avatar
hilliard is on the outskirts of columbus, along with upper arlington and dublin, its inbetween those two cities
and im lowered enough that the back tires are about half an inch inside the fender in the back
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
