Hub Centering Ring Question
Old Jan 21, 2003
are6's Avatar
are6 is on a distinguished road
I just emalied Discount Tire Direct and they have the hub rings for 10 bucks a set. But they want to know the centerbore diameter of the wheel first. Anybody know what it is off the top of your head, or do you know where EXACTLY I need to measure from to give them an accurate reading. Thanks in advance.
Old Jan 21, 2003
666's Avatar
666
666 is an unknown quantity at this point
What kind of wheels are they? You measure the distance across but not including the beveled edges on the wheel.
Old Jan 21, 2003
are6's Avatar
sorry...I got 18" Tenzo R Shu-4s...
Old Jan 21, 2003
666's Avatar
666
Measure the distance across the center hole in your wheel.....it should be about 2-5/8". If it is you will need a ring with an inside diameter of 56.2mm and an outside diameter of 66.1mm.
Sep 26, 2023 06:44 PM
NoobyKid
Jul 13, 2015 07:53 AM
muttleytm
Jul 11, 2015 06:00 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
