4 to 5 lug conversion
I'm getting some BBS wheels from a 1990s Rx-7 for my 2003 honda civic, I'm using adapters and I was wondering if there was anything I needed to know when trying to find the thickness of the adapters? I'm going to be using a two piece adapter. Also the offset for honda civic is +38mm and the offset for the Rx-7 is +40mm. This should work right?
Re: 4 to 5 lug conversion
Not sure about the adapters with regards to offset, but the range the 7thgen can take is like.. ET35 to ET44 without any other modification to make them fit. How far out do the adapters make the wheels sit (I've never used adapters, so pardon my ignorance in the matter). Also, why not just go with a true 5-lug conversion? I guess it is quite a bit more expensive, so there is that.
jringo8769
Jul 24, 2013 07:22 PM
blackbullet
Oct 6, 2002 02:35 PM
