17s on 2004 Civic
Rep Power: 0 17s on 2004 Civic
Im looking into the XXRs 521s in size 17" and was wondering what the 7th gen civics looked like with 17s..could anyone please post pics if they have any of EM2 on 17s? With given offset please and tire sizes
Dr Krieger of Modification
Re: 17s on 2004 Civic
imo 17 fit the best for the wheel wells and go low enough when lowered. 18's are nice but the amount you can lower it without major issues especially up front, is higher then with 17s.
as well i'm running 215 width which is a problem for lowering because if i go any lower the wheels hit the body inside the well when turning. so you probably want to stick with 205 width.
for performance most people run 13, 14 or 15 inch rims with beefier tires like 55s or 60s.
for looks and low I'd say 205/45/17 with a slight positive offset would work nicely.
for performance I'd say 195 to 205/55 to 65/ 14 or 15, with a slightly negative offset.
my car on 215/45/17s with a positive offset.
Prelude Owner
1st pic- 205/40/17 7" wide wheel don't remember offset +40 something.
2nd pic-205/50/16 6.5" wide wheel +45 offset
3rd pic- 185/55/16 6" wide wheel +55 offset
** Edit- I was wrong on tire specs for 3rd pic 185 not 205
Received 1,156 Likes
Rep Power: 485 Re: 17s on 2004 Civic
Click the "Azumi" link in my sig for mine
edit: hotlinking pics for ease of viewing. I'll put more pics when I'm not on my work computer. lol
He put up the offsets in a separate post. If you're asking about the 17s in the first pic, he didn't quite remember. Eyeballing it, looks about right. Stance is approximate to what I had on my 2002, and mine were +42s
Super Moderator
Received 1,877 Likes
Rep Power: 197 Re: 17s on 2004 Civic
They would surely fit but the diameter is 4% larger than stock meaning your speedometer/odometer would be 4% off. It's usually recommended to keep it within 3%. For reference 215/45r17 are just 0.4% larger diameter than stock.
The following users liked this post:
TokyoCornflower (09-03-2023)
225's have historically been too wide on the EM2/ES1 and you'll run into rubbing issues
215/45-17 has been the go-to 17" tire size. It only throws the speedometer/odometer off by .8% (speedo indicates 60mph, you'd actually be going 60.4mph). If you're hell bent on the 225 treadwidth, 225/40-17 is going to be your best bet. It does have a bigger error on the speedometer/odometer than the 215/45s at 1.4% though (indicated 60mph, actual 63.4mph). 225/40s might be harder to find, too.
here's the tool I use: https://www.wheel-size.com/
Thanks I will look that over!
Received 1,450 Likes
Rep Power: 339 Re: 17s on 2004 Civic
225 rubs on the back side
Super Moderator
I decided to go with 225/45R17 for my track tires last year. I had to raise the car about an inch and add some more negative camber. Still rubs in the front and rear a bit. Not worth the hassle.
sdaidoji (09-09-2023)
Super Moderator
Some more offset and it would probably clear but I'm not buying new wheels anytime soon.
