civic stock brakes bolt-on replacement options
Old Sep 10, 2023
pserk's Avatar
pserk is an unknown quantity at this point
Hi guys
Bought an 2002 1.6 81kw civic for tracking. Do you guys know if we have any brakes available from more powerful models that are bolt-on replacement or with minimum modifications? I can also move to 16 inch wheels if needed. As its an old car dont want to invest a fortune and hoping to find "almost direct replacement" from other hondas or more powerful versions.
Thanks for the help.
Old Sep 11, 2023
BrotatoChip's Avatar
Super Moderator
Re: civic stock brakes bolt-on replacement options
Not without going 5 lug, at least in the US.
I have read somewhere you can use Mini Cooper front rotors which have a larger diameter but cannot remember how to get the calipers working. I also track my '02 Civic and have been struggling with brakes. For your power level, there's no reason some aftermarket pads and rotors wouldn't work.
Old Sep 19, 2023
TokyoCornflower's Avatar
TokyoCornflower is an unknown quantity at this point
You can convert the rear brakes to disc, with those from the SI I believe, I haven't done it so can't comment on the ease of it. And there are aftermarket kits that have larger rotors and multi-piston calipers, but those aren't real cheap on the whole.
Are you simply overheating your currents brakes, or are more wishing to improve the stopping distance for 'limited number' of stops/braking?
Hondaboy25
May 16, 2012 05:47 PM
hcivic0120
Nov 13, 2006 11:03 PM
hcivic0120
Oct 8, 2006 05:57 PM
rockrosa
Nov 29, 2005 02:26 PM
SCRAPING530
Jun 3, 2002 11:45 PM
