brakes squeek
Old Oct 2, 2006
hcivic0120's Avatar
hcivic0120 is an unknown quantity at this point
brakes squeek
i have a 2001 civic ex and just recently when im at a stop and let off my brakes to go, they squeek. Is there any way that you can tell me if its the front brakes or the rears that are going bad? thank you.
Old Oct 2, 2006
RogerB's Avatar
RogerB is an unknown quantity at this point
Front brakes tend to go faster than back brakes, since you get more of your stopping power from the calipers than the drums.
The front brakes are easy to get at to check. Just pop the front wheels off and look between the caliper and the rotor. If you don't see much of a brake pad, it's time to change the fronts. If the fronts are fine it's probably the back.
There's a DIY on how to change the brakes in this forum.
Old Oct 2, 2006
crazea03's Avatar
crazea03 will become famous soon enough
^ wat he said
Old Oct 2, 2006
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
sounds like its time for new front brakes
Old Oct 2, 2006
simplicated1979's Avatar
simplicated1979 will become famous soon enoughsimplicated1979 will become famous soon enough
time for new front brakes..unless u just got new pads and havn't broken it in yet...
Old Oct 2, 2006
tfnaaf's Avatar
BLDNPSI Mod
if the sound is when you let off the brakes and not moving , just a guess but it sounds like the rear brake shoes making noise from rubbing on the backing plates. If not then you vshould check ALL the brakes!
Old Oct 7, 2006
streetglower's Avatar
now for awhile I always wondered what the sound was too. everytime I let off the brakes, I would hear a squeak from the rear. I believe it is from ther hardware. the return springs, and hardware for the parking brake. I replaced it and the noise went away for awhile. it came back but i dont pay attention to it.
Old Oct 7, 2006
Johnold's Avatar
Johnold is an unknown quantity at this point
is a squeek the ONLY indication that the break pads are going bad?. cause i notice after i've washed in between my breaks and rims at the car wash that they catch like CRAZY afterwords when i leave the carwash. the first 2 breakings i do with the car catch like spiderman breaks! LOL. but it goes away after i've been driving for like 5 minutes. just wondering what to look for. my car is a 2002 and i don't think the breaks were ever change yet. i can't remember what they look like. but as far as squeeks go. i don't get those.
Old Oct 8, 2006
HondaLuver's Avatar
Its a celebration bitches!
Mine squeek alot ... the brake pads arn't bad and they are stock pads.. i think they are about 50 percent... idk
Old Oct 8, 2006
tfnaaf's Avatar
BLDNPSI Mod
by design brakes will squeek. The level of noise can usually be controled via, good quality pads, new hardware, lubricated contact points, lubed slides, and proepr fuctioning calpiers
Bricoleur
Sep 9, 2015 06:48 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
