Weird ABS operation or is this normal?
This is the first car I've driven where the ABS brakes worked (or didn't have).
This happens about 95% of the time if I'm driving along at moderate speed, about 15-30mph+ and hit a considerable bump or pothole or other piece of shitty road that makes you bump up in your seat, and braking. With any pressure except extremely light, the ABS motor/action sounds like it goes really fast, which I think is normal speed, but it goes off in one or both wheels sometimes for about 1 - 1.5 sec and it sounds like a fast drum roll speed
My guess is that the bump is causing that tire/side to lose traction just enough that the ABS kicks in? I thought it was supposed to stop once you have a non skidding wheel again.
I don't know if this is normal or if that's a problem. It has been in an accident where the front left wheel, axle, and suspension were damaged, so they were recently replaced.
Re: Weird ABS operation or is this normal?
We dont have traction control we only have regular abs brakes, could be a problem
hmm ive always avoided braking when going over bumps and potholes so couldnt say if its normal. i know these cars abs system is really sensitive tho.
no it's normal the abs is too senstive and when you hit a bump it will set it off mine used to do it all the time till it got till the abs modulator got burned out.
Autocross Junky
familiarize your self with abs
http://www.stoptech.com/tech_info/wp...rakekits.shtml
(dont worry about reading the BBK part, just the description of what ABS is actually doing)
BootyDo
Jul 26, 2015 10:38 AM
Touge
Jul 18, 2015 05:37 PM
Touge
Ottawa
Jul 18, 2015 05:35 PM
1khilari
Jul 9, 2015 08:12 PM
