Help on proper tire pressure for 245/45ZR/17
Autocross Junky
Re: Help on proper tire pressure for 245/45ZR/17
Tire pressure is mainly based on weight. And it is clearly marked in side the drivers door sill. you may as an option increase that designated psi by 1 or 2 lbs if you like.
^no. the sidewalls tell you the MAXIMUM pressure allowed to safely operate the tire.
our pressure is somewhere along the lines of 30-32psi
^^^^^^^ that is correct... just run 33 or 34 with a tire like that running 32 might be a little to soft and then you run the risk of a nice blowout off a pot-hole well actually reguardless a tire like that will suffer from anything but smooth *** roads. good luck
i run 31ish psi during the summer time and about 32psi during the winter...
but here in cali, the temp doesnt really ever change.... 75degrees of sunny blue skies year round
i like 35 psi in the summer its not too harsh. in winter tho everything is very stiff.
Causemo
Jul 4, 2015 07:11 AM
bo_red
Apr 23, 2015 10:09 PM
