Time for new tires. need advice
Old Apr 19, 2006
dallasaudio's Avatar
dallasaudio is an unknown quantity at this point
Currently I have 205/40/17 yokohama parada spec2 tires and I want to go with somthing different this time around. I like the way they stick but their tread life is short and road noise is pretty bad. I want to go with a 205/45/17 this time. I want somthing more "all season" this time that will still have good grip but wear better and less road noise. I want to stay around 110.00 a tire. Any suggestions? Thanks
Old Apr 19, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Go 215/40R17. Thicker sidewall then 205/40. As for the actual tire, I got Continental ContiextremeContacts, which was 117/tire from Wal-Mart special ordered. They're all season rated, and even have excellent snow grip.
Old Apr 19, 2006
215/40/17 is not a thicker sidewall, just a wider tire? Maybe I'm wrong....
Old Apr 19, 2006
Wanna bet? 40% of 215mm is more then 40% of 205mm
Old Apr 19, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I roll 215/45/17 Nitto Neo Gen!!!!
Nitto, Nitto, Nitto!!! IMO
And, yes 215 is more tire then the 205!
Old Apr 19, 2006
What are the advantages of a 215/40/17 over a 205/45/17. My main objective is tread life and road noise. I'll get some serious street tires when I do my engine swap which will be in the next few years.
Old Apr 19, 2006
I have 215/45R17's on my car. I hate the way they look. The tires look way too thick for my liking. Going from a 205/40 like I had to these ones was quite an adjustment. Also when I lowered my car the tires rubbed on the rear fender lip and on the front under turning. If you look at a tire calculator,
The 205/40 sidewall is 3.2 inches high and makes the speedo -2.5 MPH off.
215/40's are 3.4 inches high and make your speedo -1.6 MPH off.
205/45's are 3.6 inches high and make your speedo -.5 MPH off.
215/45's are 3.8 inches high and make your speedo +.5 MPH.
The reason I want to go with 215/40's is that it is a lower profile then 215/45 (I've seen them in person, the difference is quite visible) The road noise isn't that much more noticeable with the 205/40's on, I've driven with both and I could only detect slightly less noise with my 215/45's on
Tread life has more to do with the tire construction, how you drive, and if you keep your car in alignment.
Old Apr 19, 2006
02BLKCIVIC's Avatar
^^^^^Good advice^^^^^
If you are able to SEE a 215/24 on a RIM, the tire sora "hangs over" the edge of the rim. ( to protect from curbing & aditional handling)
205/40 Wont have the "extra" edge.
Did that even make any sence????
01honder is correct also, Less noise with 215's! IMO
Old Apr 19, 2006
I mostly drive highway and i'm not overly aggresive but sometimes I can be. I can get BF Goodrich g force sport's for 115. Any input on these over Yokohama or Cooper?
Old Apr 19, 2006
02BLKCIVIC's Avatar
Yokohama > BF
Yokohama > cooper
Nitto > yokohamo
IMO!
Old Apr 19, 2006
JB Dizzle's Avatar
JB Dizzle has a little shameless behaviour in the past
i hear the toyo proxes-4's are pretty bad ***
Old Apr 19, 2006
WhiteHalf's Avatar
WhiteHalf is an unknown quantity at this point
I'd suggest for a good Z rated (all season) I'd go with the Falken Ziex 512
I've got them on my car and they have a treadwear rating of 320 or 360 or something great like that.
Basically they're a Z that is warrantied for up to 40,000km's.
Check those out ... I like'em
Old Apr 19, 2006
Thanks whitehalf. I actually had a friend tell me the Falkens were good tires, and cheap too.
Old Apr 19, 2006
WhiteHalf's Avatar
Yup ... this is the 3rd season ... and theres at least half of the tire still left. I only drive low km's per summer season anyways ... BUT ... I know guys that have gone through entire full sets of Z's since I've had mine ...
So $$$ in my pocket = good.
Old Apr 19, 2006
HondaLuver's Avatar
Its a celebration bitches!
i had 225/45 on 17x7... i loved it...
Old Apr 19, 2006
I was going to get them at discount tire but they don't carry the size I need. Any other good places online? Thanks for the help guys.
Old Apr 19, 2006
www.tirerack.com
Old Apr 20, 2006
02BLKCIVIC's Avatar
Im a big fan of discount... just because they warrantee EVERY THING they touch!
Old Apr 21, 2006
gotarheels03's Avatar
gotarheels03 is an unknown quantity at this point
if you are getting Falken 512's then www.vulcantire.com is by far the cheapest place.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
Jigee
May 9, 2015 11:18 AM
GH04si
Apr 15, 2015 08:13 PM
