e-brake emergancy
Old Nov 27, 2005
civicspeedster's Avatar
civicspeedster is an unknown quantity at this point
e-brake emergancy
my e brake is broken like dosent work at all so i assume its just worn out over time since i bought the car used but my question is can i fix it my self or is it somehtin i need to get done if so then how???
Old Nov 27, 2005
savedadogs's Avatar
savedadogs is an unknown quantity at this point
You need to tighten the cable. There is a DIY, do a search.
Old Nov 27, 2005
R1Style's Avatar
when you pull the ebrake cable is there any resistance? You might have snapped the ebrake line... get it checked out.
Also check your rear brake shoes to see if they're worn out.
Old Nov 27, 2005
no theres no restiance what so ever unless its completely all the waty up even then its not that great of resitsance so what should i do?
Old Nov 27, 2005
CraigW's Avatar
How does it work when parking ?? The one in my 05 would be almost worthless for anything but as a parking brake.
The cables could be stretched, the adjustment may work but do not tighten too much.
Old Nov 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
pull a drum off make sure that theres lining left first.
Check the auto-adjust levers in the drum and make sure they're working (its the threaded rod, there's a finger that advances it and a spring that pulls it back (just below the wheel cylinder).
While you're in there, make sure the e-brakes are connected (behind the shoe towards the bottom)
If that stuff looks in order, then search for how to adjust the e-brake cable (its posted numerous times).
It sounds like the cables just need to be tightened.
blward6
Sep 16, 2015 05:32 PM
