steering wheel shakes bad when braking?
Old Nov 20, 2005
hassanperryon's Avatar
hassanperryon is an unknown quantity at this point
I was just wondering how I should fix this problem? I just got my alighnment plus 2 new front tires with all 4 wheels balanced. My car is lowered on neuspeed sports with neuspeed stut bar, x-brace, and 215/35/18's.
The problem usually occurs when driving 60+ on the freeway and when I brake the steering wheels shakes including the pedal(very unbearable)
Could it be the X-brace?
or
Could it be warped rotors?
Old Nov 20, 2005
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
yep almost sure its warped rotors....get it resurfaced if you havent already and if you have, check to see if it can be resurfaced again. Otherwise, time for new rotors.
Old Nov 20, 2005
dalaw's Avatar
Bone Stock!
Most likely warped rotors. My mom's camry used to do that and she paid $80 to get the rotors resurfaced and now her brakes are smooth as glass.
Old Nov 20, 2005
Forgot to mention that I haven't changed my brake fluid for 45,000 miles
Old Nov 20, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
just get your brakes done have them check the pads usually low if the rotors are warping and they can drain the brake lines. i took mine to a all japanese car shop and they resurfaced the rotors, replaced the brake pads and tightened my e brake up for $150. my car stops on a dime.
Old Nov 20, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Its very likely that the rotors are warped. Its cheaper to replace them than it is to resuface them. New rotors are $20 each at autozone, just pick up a set, pop em on, don't forget to break them in and then have at it.
Old Nov 20, 2005
CraigW's Avatar
Warped rotors, And at 45k the pads may be near the end as well. I quit having rotors turned long ago (they always warp again soon afterward, usually worse than before) I run them until I cannot stand it anymore and then replace them.
Old Nov 20, 2005
Pads are still new, I put ceramic pads on when I painted my calipers red,I'm thinkin bout gettin powerslot cyro slotted rotors or gonna get the powerslot big brake upgrade.
Which one will perform better?
also gonna get russell ss brake lines when I change the rotors.
Thanks.
Old Nov 20, 2005
powerslot cyro slotted rotors our cars are already so light a big brake upgrade is overkill
Old Nov 20, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
how would you break new rotors in?
Old Nov 20, 2005
Jap-Euro Fusion
5-10 stops with medium pressure from 40 to 5,5 minutes cooling time then 5-10 stops with hard pressure from 40 to 5, 10 minutes to cool, then 500 miles without beating on the brakes.
Old Nov 20, 2005
i just hit the brakes that is breaking them in for me. i dont slam on my brakes to begin with.
Old Nov 21, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
everyone says warped rotors...couldn't it be that he has buildup...or w/e the term is for when pad material builds up on rotor surface and causes the same symptoms as warping? but like boilermaker said its probably cheaper and alot more peace-of-mind to just change them out with a/z blanks....
Old Nov 21, 2005
01vic's Avatar
ultra super duper member
01vic will become famous soon enough01vic will become famous soon enough
is there noise along with the shaking? mine shook when i needed the rear drums adjusted.
anytime i was on the highway and had to slow for an exit or car ahead of me the car would shake and make nasty vibrating noises.. just a thought
Old Nov 22, 2005
SinaloaCivic's Avatar
Ill punch you in the face before you visit Myspace
SinaloaCivic is an unknown quantity at this point
i have the same issue it vibrates when i hit the brakes at higher speeds like 50-60 MPH but i only have 16K miles.....is this right ro do i go to the dealer?
-PeTeY!! ::EM2::
conspiracy90
Jun 7, 2023 01:01 PM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
Optimus34
May 25, 2015 11:52 PM
bsmiley
Apr 27, 2015 01:27 PM
RickyRocket
Nov 30, 2001 10:14 AM
