How to clean rear drums?
Old Oct 31, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Ever since ive had my rims on, im constantly bothered by how dirty my rear drums look. Its so ****in ugly, the copper rust color. Is there a way to clean them? Or what would I maybe replace them with?
Old Oct 31, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Get some high temp paint, and paint them
I did mine in black
Old Oct 31, 2004
zen_master's Avatar
well, get urself a new drum...and paint em....probably not black...gunmetal will look good...i saw one before....
painting rusted drum could be a pain in the a**
Old Oct 31, 2004
Vinnie's Avatar
you think i could sand it? or how much is a new set of drums...
Old Nov 1, 2004
streetglower's Avatar
new set of drums, at least $100 if you get OEM ones, but look up brembo drums, I have seen them for less then $100.
Old Nov 1, 2004
Vinnie's Avatar
and then how do i protect my investment from being rusted again
Old Nov 1, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
wtf...Brembo makes drums...wow i never thought Brembo would make a part for a shitty brake setup
Old Nov 1, 2004
civictuner's Avatar
paint it.... like nice.... w/ 1st a rustproofer then high temp paint and ull be good
Old Nov 1, 2004
Zzyzx's Avatar
Autocross Junky
Brembo Makes brakes and brake parts, which include Drum brakes... its how the company makes $$$.
and Rear drums on light cars are not all that bad. the only real down side to them is issues with overheating, which can be compensated for by running the right temp compound on the Shoes.
Vinnie, to stop them from getting rusted, you need to Clean them often, and You need to spray them with High temp paint. Brakes rust, its something they just do. (chec k out your disks in the front, and you'll find rust. (Heat + water/Road grime/Ect = Rust).
Old Nov 1, 2004
Vinnie's Avatar
thanks for the info guys
Old Nov 1, 2004
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
You forgot metal!
Heck,
(Metal + Water = Rust)
Old Nov 1, 2004
4jacks's Avatar
Ohhh I forgot !!
Yes, you can Sand Down and Paint your Existing Rusty Drums,
You probably only wanna sand down and paint the Drum Cover..
Just pull off the Drum cover, Go to home depot and get spray Orange paint Stripper, I forget the product name But it's Real Orange, can't miss it . And it says ORANGE real big. It will help with the rust, but you will still need a metal file. get a metal file and take everything down to the Steel. The paint stripper, will take the clean spot to the steel, use the metal file to take the rest to the steel.
Then use High temp Primer and High temp Spray Paint..
They make a New Bright Pink Color, You'll be Bling Bling Baby !!!
Total will be under $20 not $100
Old Nov 1, 2004
HondaLuver's Avatar
Its a celebration bitches!
u should see my disc brakes , it looks so rusted.. (my car hasn't been anywhere fo the past 2 months
Old Nov 4, 2004
Nodnero's Avatar
Yeah, either rear discs are nice . . .
Old Nov 4, 2004
4jacks's Avatar
Or ??????????
Old Nov 4, 2004
someguy's Avatar
someguy is an unknown quantity at this point
Originally Posted by 4jacks
Or ??????????
yeah...your probably right.
Old Nov 4, 2004
pon55's Avatar
You forgot metal!
Heck,
You forgot Salt!!!!!!! (Metal + Water + Salt = Great Rust)
Old Nov 4, 2004
HondaLuver's Avatar
salt? in california... bleh.. dam my front and rear discs are crap...lol
Old Nov 4, 2004
pon55's Avatar
I was refering to us" po easterners"! When it looks like it's gona snow they put salt on the roads. I'v had cars set for a few months and the pads would rust in place. Cali does have its good points!
Old Nov 4, 2004
ArtIntown11's Avatar
The Original F*ckin Angry Armenian
ArtIntown11 has a little shameless behaviour in the past
i got rear discs oh man they are good....rear drums are nice but i would just swap em like i did. zzxyz what is the name that company that makes racing shoes and pads, i believe it starts with a P or something, porter____ or something or the other, i forgot you posted something about them a while ago.
Old Nov 5, 2004
Zzyzx's Avatar
Autocross Junky
Porterfield
http://www.porterfield-brakes.com/
Old Nov 8, 2004
sevenplaces's Avatar
I want a TSX!
sevenplaces is on a distinguished road
use a wire brush!!!
sbi
20
Oct 23, 2015 01:34 PM
rtachs
Jul 16, 2015 05:32 PM
Optimus34
May 25, 2015 11:52 PM
rhvic
May 22, 2015 03:06 PM
ayzan
Dec 28, 2001 10:47 PM
