rear drums?
Old Apr 22, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
rear drums?
how do i change the rear pads in my drums?
they are leaking black dust, im guessing they need changing
riley
Old Apr 24, 2004
HondaLuver's Avatar
Its a celebration bitches!
don't knowo man
Old Apr 24, 2004
CRNewson's Avatar
CRNewson is an unknown quantity at this point
Let's start simple:
SAT Analogies
Disc brakes : Pads :: Drum brakes : Shoes
You want to change out the brake shoes. Drums don't have "pads" like discs.
You must disassemble the drum brake. They're all about the same (drum brakes that is) so you should be able to look at any Haynes/Chilton type manual and figure it out. If I had better instructions, I'd help you out, but I'm afraid that I don't.
Hope this helps a little bit.
Old Apr 24, 2004
HondaLuver's Avatar
^^^^ don't try to act smart newbiee... if he search somewhere he might have found it, but people like u have to be a **** about it
Old Apr 24, 2004
streetglower's Avatar
Just go to a shop, cost you maybe around $50-60.
Old Apr 24, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
u should prob have somekind of manual n e way i have the dealer one!! hahaha i got lucky. just cuz there new to the site doesnt mean there noobs to cars. and as for the rear drums i havent done mine yet but "in gneral" with your tire off there will either be no screws or two going through the outer plate. if so remove, than pull the outer plate off usually needs some persuasion, aka hammer. and just cuz there's dust doesnt mean u need new shoes.
Old Apr 24, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
i know how ima do it... shoes aree 15$ and when i get my studs pulled to put lug bolts and stud lugs(like a mercedes) ima have them changed.
riley
Old Apr 25, 2004
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
i'm not sure if these are the right directions but i saw my mechanic do it...
-you take like a bolt and practically stab it in the rear drum (it seemed like it was really soft...make sure your e-brake isn't up)
-than you take an open end wrench and unscrew it out till it gets loose and than the rear drum should come on loose and you'll see the inside of the and get to the "shoes"
Old Apr 26, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
hmmmmmm ... go to the dealerships and ask
Old Apr 26, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
i got a guy doing it
Old May 30, 2004
how much are the manuals from honda anyway? I have checked autozone, pepboys, no one has one for our car.
Old May 30, 2004
sjoback's Avatar
sjoback is an unknown quantity at this point
just go to http://www.helminc.com and order it directly. same one that the dealer will sell you.
they are about $70, plus shipping
Old May 30, 2004
thecheat's Avatar
thecheat is an unknown quantity at this point
guys, this is so easy. take the wheels off. Use a putty knife and a screwdriver to remove that gold center cover on the drum. Use a punch to un-detent the big nut under it (if you get this far you will see what I mean). Un screw the nut. the drum falls apart in your hands. Clean the dust out with brake cleaner. Inspect the shoes. If they need to be replaced (1.6mm is minimum spec, new is around 6mm I think) swap them with new ones. Clean everything real good with the brake cleaner and reset the little ratcheting tensioner. When you put the nut back on, it gets torqued to like 130lb/ft but get the exact spec from your dealer so you dont screw it up. detent the nut so it doesnt come off. tap the cover back on. put the wheel on and torque the lugs to 80lb/ft. your done. easy stuff maybe an hour for both sides and you get to inspect the rear suspension yourself rather then trusting some hack at the dealer. once I get some cash to get another set of pads and shoes I'll do a full DIY with pics. I havent seen one on here before
Old May 30, 2004
sjoback's Avatar
why do you pull the spindle nut off? I don't see how that would help.
Old Jul 5, 2004
conspiracy90's Avatar
conspiracy90 is an unknown quantity at this point
http://www.honda.co.uk/owner/CivicManual/index.html
Click on conventional brakes then download the 3 pdf files from Rear Brake Shoes.
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Saratoga
26
Oct 2, 2015 09:05 PM
Sep 27, 2015 11:33 AM
czarlun
Sep 14, 2015 08:16 PM
