Front disks
Old Sep 20, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Front disks
I thinkinf of going with 15 inch wheels for my car, and geeting turbo by thre end of the year, my questions is would the stock brakes be able to handle it??
or cound those who have OEM size slooted rotors, with diffeent pads think thats enough??
or maybe upgrade the rotors up front and do a rear disc conversion??
Old Sep 20, 2003
Zzyzx's Avatar
Autocross Junky
depends on how and where you're driving
The breaking power a car needs is dependant on that cars weight not its HP. if you are really that concerned, upgrade the front rotors to a slotted rotor, and get Higher temp pads. Then get higher temp break shoes for the back. if you REALLY want to stop faster, get better tires.
Old Sep 20, 2003
thanks, i was mistaken that, but yeah i don't like the braking even with parada sepc-2's
Old Sep 21, 2003
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
upgrade the pads and switch to stainless steel lines that will make a difference along with the tires
Old Sep 21, 2003
where could i get good stainless steel lines??
Old Sep 24, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
Goodridge makes 'em. Just ask any performance parts store.
Old Sep 24, 2003
Zzyzx's Avatar
Autocross Junky
Braded break lines dont actually help you stop quicker or give you more pressure on the pad. What they do, Do is give you a bit of added safty Vs the line being cut or damaged and they reduce Flex in the break line giving you more positive feed back from the breaks them self (Giving you more feel of what the breaks are doing/more control).
Like I said, if you want to shorten your breaking distances get better tires. Even if you upgrade your Pads and rotors, all thats going to give you Better resistance to break fade. Sure the pad is going to grip the rotor better, but its your tires that are actually stoping you.
So
1 Upgrade Rotors = Better Resistance to Break Fade
2.Upgrade Break Pads = Better Resistance to Break fade and Possibly more control over the breaks.
3.Upgrade Break Lines = Better Break Feedback= Better control over breaks.
4.Upgrade Tires to a stickyer compound = Shorter Breaking Distances
5.Upgrade wheel to A lighter wheel = Shorter Breaking distances + increaced acceleration.
Old Sep 24, 2003
thanks...
Old Sep 24, 2003
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Steel lines will help a bunch. You wont have to push the pedal down nearley as far to get better breaking... less time pushin the pad = quicker times on an auto x track
~nick~
BootyDo
Jun 21, 2016 03:45 PM
Misfit2613
Jul 30, 2015 09:49 AM
jzhartman
22
Jul 23, 2015 10:42 PM
Jul 14, 2015 03:39 PM
muttleytm
Jul 11, 2015 06:00 PM
