Break question
Old Aug 8, 2003
GrlCivic01's Avatar
GrlCivic01 is an unknown quantity at this point
Question Break question
My breaks are going out (grinding noise) and I wa wondering which breaks should i get.
Old Aug 8, 2003
Zzyzx's Avatar
Autocross Junky
Grinding noise!!!!! you brakes arn't going out they are totaly shot........ Get them Fixed IMIDIATLY!!!!!!
Youll probably need rotars, Brembo blanks are good, so are power slot or EBC.
As far as pads, well that depends on what you do with the car. Stock pads would work so would AEM pads. If you're looking for a bit of performance go with EBC green stuff or redstuff. Hawk makes good pads too.
Seriously, you need to get your breaks fixed ASAP. Grinding noise = metal on metal = Poor breaking power+possibly major break componant damage (Caliper) and that can cost big $$$$$$$.
Old Aug 8, 2003
GrlCivic01's Avatar
Thanks for the info, i was looking at th EBC Greenstuff on tire rack,
i just got my shocks put on yesterday I was happy until this morning when my beaks did that.
Old Aug 8, 2003
flotsamm's Avatar
Could just be the squeek indicators making the grinding noise. The purpose of the squeek indicators is to let you know its time to get the brakes done. If you can see the front rotors, look to see if they got grooves in them. If they look smooth, then you might just need a simple front pad/rear shoe replacement. If theyre grooved, your going to want them resurfaced(about 10 bucks a disc/drum) and new pad/shoes installed.
Old Aug 8, 2003
GrlCivic01's Avatar
Yeah, it's not a REAL Bad grinding noise but u can hear it when i break, do we have rear and front breaks or just front I 'ma dumb girl so i don't know J ust kiddin' !!
Old Aug 8, 2003
Zzyzx's Avatar
Autocross Junky
Our cars have Front Disc breaks, and Rear drum breaks. just ask away. the only dumb question is the one thats not asked.
Old Aug 8, 2003
Weaponx12o's Avatar
so true (only to a certain extent ) but yea, get yours brakes checked and make sure they arent warped, if they're not, then just get new pads. if they are get new rotors and pads.
Old Aug 10, 2003
Jas88's Avatar
Jas88 is an unknown quantity at this point
what are the best aftermarket brake discs for an 03 civic?. I want to use the stock brake calipers. I've heard that the AEM brake discs arent that good. I was thinking of Baer brake discs
Old Aug 10, 2003
Zzyzx's Avatar
Autocross Junky
Depends on what you do with the car.
I'd say that most of us only need something like a Bembo Blank, or something simalar.
If you'er in to autocross or drive really hard (and lay on the breaks allot) then a good slotted break would be good.
I dont recomend Drilled breaks for any thing but Show.
a good set of pads and Tires will help breaking more then rotors. a good set of rotors will just be able to withstand/dessipate the Heat better.
Old May 9, 2004
Philip's Avatar
Philip is an unknown quantity at this point
I have got Power Slot sloted rotors and Hawk pad; it stops not only a bit better but it could also withstand multiple hard breaking session at a time. the only downfall to this setup is it's hard break pad compound with Hawk....it makes a really annoying jet plane winding down/popo siren sound alike during slow speed partial braking.....and one more piece of advice is to flush your braking system and get some DOT 4 into that system. I notice a good difference with that setup
civic98?
Aug 13, 2015 01:32 AM
NoobyKid
Jul 13, 2015 07:53 AM
Causemo
Jul 4, 2015 07:11 AM
