Customize your car Post here for any custom modifications you want to to to your car!
Sound deadening project
Old Sep 21, 2019
Banzelcroft's Avatar
Banzelcroft is an unknown quantity at this point
I'm a long time reader and first time poster so forgive me if I'm in the wrong section. I recently purchased a 2014 Civic and I'm planning on ripping everything out to deaden the road noise but was looking for clarification. Am I correct that the CLD panels attach to the metal directly, then neoprene on top of that, then the mlv on the very top before putting everything back together? Does that cover all of it or am I missing a step or two? Any input would be appreciated and again sorry if I'm in the wrong area.
Old Sep 21, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Sound deadening project
Not sure about all of that, as I have a 7th gen.
But expanding foam set in custom cardboard trays (which would be removed before the foam was installed), then trimmed would work well.
Old Sep 21, 2019
I had seen that expanding foam was a usable option but that stuff always struck me as a little messy to work with.
Old Sep 21, 2019
mac25's Avatar
It can be but I was fine using it.
-you'd have to make your trays to fit each area in the car (cardboard or foam core with hot glue)
-use a mold release agent, or wax paper so the foam parts dont stick to the trays
-spray in the foam, but not to the top since it expands (obviously dont try to use the foam directly in the car)
-let sit 24 hours
-trim
-remove from trays
-install.
Old Sep 22, 2019
That actually sounds much easier than what I had pictures, maybe I'll rethink how I want to do this.
joncom
Oct 31, 2010 11:42 AM
gatorsactions
25
Mar 3, 2005 05:05 PM
gearbox
Aug 29, 2004 03:33 PM
Forum Bot
General DIY
May 14, 2004 09:44 PM
Roosbok
Apr 24, 2003 11:21 AM
