Air Conditioning Post issues about air conditioning here
AC problem
Old May 9, 2023
Grumpy2lo's Avatar
Grumpy2lo is an unknown quantity at this point
AC problem
I changed compressor cuz was bad had charge on it when bled off completed it can't get it to run now tried jumping pressure switch nothing swapped relays no change checked all fuses nothing blown,fans are running and I can make it run by running hot wire to center pin on compressor so changed control panel inside still not running by the button inside but when hooked the way I got it then it runs and gets cold any help I would appreciate it Thanks
Old May 10, 2023
BrotatoChip's Avatar
Super Moderator
Re: AC problem
-The A/C button inside works? The light comes on?
-Both radiator fans come on as soon as you press the A/C button?
Have you checked the compressor thermal protector?
Old May 10, 2023
Grumpy2lo's Avatar
Re: AC problem
No I haven't check it I guess I'll go do that
Old May 10, 2023
Grumpy2lo's Avatar
Re: AC problem
I will let you know if it works
Old May 13, 2023
Grumpy2lo's Avatar
Re: AC problem
Yes I checked thermo on compressor and it's good I'm confused now
Old May 14, 2023
Colin42's Avatar
Re: AC problem
Whay are your pressures high and low?
jerseykid418
May 2, 2017 08:21 PM
mrb420
Jan 21, 2006 11:34 AM
Dakker
Nov 6, 2005 03:46 PM
kfk256
Feb 2, 2005 08:56 PM
