Air Conditioning Post issues about air conditioning here
A/C Compressor and Condenser Fan no power from relays
Old May 14, 2023
rayjwhitney's Avatar
rayjwhitney is an unknown quantity at this point
Unhappy A/C Compressor and Condenser Fan no power from relays
Hey guys,
2006 4 Door Honda Civic DX
just looking for help on what to check-
A/C didn't work. Charge was low.
No power to compressor or condensor.
Relay checks out. All fuses are fine.
Jumped power across the load side of the 2 relays and compressor kicks on and fan kicks on.
When recharged, high side stayed low and needle vibrated. Low side climbed. Replaced Expansion Valve and recharged.
Got a fully charged system.
Still no power to compressor and to condenser fan.
When I hope across the load side of the relays, a/c works fine.
Neither relay is getting ground on its signal side.
Ground appears to be within the PCM.
Is it possible the A/C Control unit is bad? Has anyone seen that?
Is there anything else that would disable both components but allow the system to work fine when jumped?
Or am I looking at a bad PCM or ground?
Any help is appreciated.
Ohmster
Air Conditioning
May 23, 2021 08:10 AM
munson5501
Aug 19, 2018 04:12 PM
Thundar
Air Conditioning
Sep 17, 2017 10:30 PM
maintman47
Mar 18, 2014 09:00 PM
bigmacnfrys
15
Apr 16, 2011 04:46 PM
