Air Conditioning Post issues about air conditioning here
Ambient temperature sensor & wiring harness missing
Old Sep 20, 2021
Fernandop255's Avatar
Fernandop255 is an unknown quantity at this point
Hi!
recently bought a 2008 civic lx and it’s solid. Turns out the only issue is the a/c is cooling intermittently and after running diagnoses i found out that the car was involved in a front crash and when they repaired it seems that they ripped off the ambient temperature sensor and also the wire and plug. I tried looking for the wiring and it’s missing.
i was wondering if i can get the wiring and plug plus the sensor and merge the cables with any of the connectors close to the radiator (the condenser or radiator fan, maybe?).
any advice on how could i fix this? Much appreciated, thanks!
Old Sep 20, 2021
CraigW's Avatar
Re: Ambient temperature sensor & wiring harness missing
LX never had it to start.
Old Sep 20, 2021
Had no idea of this, thank you!
The clutch is engaging and it cools for a little bit but the lines are freezing up and clutch stays engaged until that happens, after that it blows warm air.
What would you think i should check then?
Thanks again!
Old Sep 20, 2021
Colin42's Avatar
Dirty cabin filter, over or under charged system, bad pressure switch
Pete6032
Jan 14, 2015 10:17 PM
pantdino
15
Dec 6, 2014 11:52 AM
jordan101
Aug 16, 2011 11:03 AM
bboytius
Feb 23, 2008 07:05 PM
bboytius
Aug 17, 2007 02:31 PM
