1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1993 civic map sensor prob
Old Aug 14, 2011
jordan101's Avatar
jordan101 is an unknown quantity at this point
i have a 93 civic cx and i did a motor swap to the b7. My check engine light is showing bad map. Well i looked under the hood and no map. i researched online and i guess the cars that had the b7's the map was on the firewall. So then i bought a map sensor and now i cant find the plug. i read online the firewall map sensor has it own harness that goes through the firewall and doesnt connect to the engine harness. What should i do so i can plug a map up.
Old Aug 15, 2011
jordan101's Avatar
Re: 1993 civic map sensor prob
can anyone help i have no clue on what to do
Old Aug 15, 2011
lazlong's Avatar
Could it be number 10? http://www.hondapartscheap.com/south...t=0&quantity=0 (click to enlarge pic)
You could try calling Honda but, I've pretty much lost confidence in the dealers.
May want to go to the salvage yard and pull one.
Did you use a B7 harness? It may be on the B7 harness.
Old Aug 15, 2011
jordan101's Avatar
yes i used the b7 engine harness but like i said i did research and it said its nopt connected to the engine harness it goes in directly through the firwall and to the ecu. So do i need to run the sensor directly to the ecu? If so i have no clue where to slice in.
Old Aug 16, 2011
lazlong's Avatar
I would try to get one at the salvage yard first. As to making your own harness I'll do some research and get back to ya. I know you'll need connectors to make the harness tho.
Old Aug 16, 2011
jordan101's Avatar
k and ya that would be great. Are the interior harness just about the same on the cx and dx length wise. If i bought inside harness i could just swap it out than i would have the connector unless it less pain to create my own harness.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Pr0n1s
Apr 30, 2015 03:08 PM
bsmiley
Apr 27, 2015 01:27 PM
Civicman92296
Apr 23, 2015 09:22 PM
locozoko
Nov 28, 2001 05:48 PM
