Air Conditioning Post issues about air conditioning here
Recirculating Button 2013 Civic [solved]
Old Jan 16, 2021
Richard Jr's Avatar
Richard Jr is an unknown quantity at this point
I have a 2013 Civic Ex. When I turn the ignition on the recirculating light comes on then goes off. Sometimes it comes on and stays on. The problem is when it is off, the a/c fans do not work. Are they connected somehow and why would the recirculate button be intermittent ? Sometimes when the recirculating button is working, when I increase the fan speed, the engine RPM increases really high which is very unusual. I know putting a load on the engine can cause an increase in RPM, but this is a little more that it normally does. I did not find any fuses or relays bad, but it may because a relay is intermittent, I don't know. If anyone has any ideas what is going on, I would appreciate the information. I thought maybe it was the car battery but I had that checked and it is fine. Also, all the other features on that panel seem to work, just no fan blowing with the recirculating light not working. Thanks for your help.
Old Jan 16, 2021
Richard Jr's Avatar
Re: Recirculating Button 2013 Civic
Does anyone have a clue what this problem may be ?
Old Jan 17, 2021
Richard Jr's Avatar
After pulling the air conditioning console out and back in about 8 times because I either forgot something or something wasn't working just right. I went on to see if there was power to the A/C blower motor and there was. I decided to pull the fan out and connected it to a 12 volt power supply and it was good. I hooked everything back up without installing anything and tried it out and the A/C fan was working correctly and the recirculation button was working normal again. I had to come to the conclusion that it was a bad connection between the power supply and the blower. I assembled everything back and had no parts left over, so I must have done it right. I got away cheap this time and didn't have to go to the dealer to get it repaired.
Old Jan 17, 2021
glad you found the issue. Our response would have been check the wiring...
Old May 11, 2022
GreenTea713's Avatar
GreenTea713 is an unknown quantity at this point
I’m having the same issue! The recirculate button only works when the car just turned on, or at very random times it will actually stay on. But when the recirculate button doesn’t work, my a/c feels warm. Was it an easy fix to complete on your own?
Old Feb 21, 2023
Illusive Man's Avatar
Illusive Man is an unknown quantity at this point
were you able to figure this out? I’m having the same problem
Old Feb 21, 2023
Where is it located and how do you get to it?
Old Feb 21, 2023
Re: Recirculating Button 2013 Civic [solved]
did you try the troubleshooting already in the thread?!? If not, start reading and doing
Old Feb 22, 2023
I can’t troubleshoot if I don’t know the location of the fan or how to get to it. Can you provide more information?
Old Feb 22, 2023
behind the dash, pull the AC console out
Old Feb 22, 2023
buy also a repair manual
https://www.civicforums.com/forums/2...hase-them.html
Old Mar 18, 2023
Took it to 3 different mechanics and they said it was an electrical issue…freon level is fine… they recommend replacing the compressor. Are the hybrid compressors,which are very expensive, all that different from standard 2012 civic compressors?
Old Mar 18, 2023
Colin42's Avatar
Yes.
jobz
Dec 14, 2017 10:04 PM
buster 1
Jan 2, 2016 05:38 PM
thunderfck23
Jun 2, 2013 10:03 AM
mkollek
May 23, 2009 02:50 AM
noakail
Oct 17, 2005 02:43 PM
