Air Conditioning Post issues about air conditioning here
air conditioning on and off
Old Apr 20, 2020
mustfirst's Avatar
mustfirst is an unknown quantity at this point
2007 Coupe LX Civic
My AC goes on and off. I bought a new relay and put it in. The AC is still going on and off. I really thought it was the relay but it's not. Can someone let me know how I can fix it? Thanks
Old Apr 20, 2020
BrotatoChip's Avatar
Super Moderator
Re: air conditioning on and off
The air inside the cabin is cold then warm, then cold again? Or the compressor is cycling on/off?
Old Apr 20, 2020
chuffsy's Avatar
chuffsy is an unknown quantity at this point
You could be low on freon
Old Apr 21, 2020
mustfirst's Avatar
Yes, the vent is blowing cold air, then when i'm driving for a while, it won't blow cold air. But today it blew cold air all day, i drove for 1.5 hours round trip to work.
I'm not sure about the compressor thing, if you can explain i can try to find out.
Old Apr 21, 2020
mustfirst's Avatar
How can i find out?
Old Apr 21, 2020
Colin42's Avatar
You need a set of manifold gauges, if you zero experience working on AC systems you're better off leaving this to professional mechanics
Old Apr 21, 2020
Super Moderator
Given the age of the car and your brief description it could just need the compressor clutch adjusted.
Old Apr 21, 2020
chuffsy's Avatar
When it is not blowing cold do you find that the air flow "strength" is reduced? Do you know what the ac compressor looks like and can you find it when you open the hood? If yes do this the next time it stops blowing cold. Turn off the ac , green light should go off. Open the hood and see if the compressor is running. The front of the compressor has a clutch and if the compressor is running it will be turning . Google auto air condition compressor if you are not sure to see what it looks like. If the clutch is engaged .meaning turning, then the ac control panel in the car is bad and needs replacing . The clutch should not be turning with the ac switch in the car in the off position ( no green light).
Old Apr 21, 2020
mustfirst's Avatar
When it is not blowing cold do you find that the air flow "strength" is reduced? If yes do this the next time it stops blowing cold. Turn off the ac , green light should go off. Open the hood and see if the compressor is running. The front of the compressor has a clutch and if the compressor is running it will be turning . Google auto air condition compressor if you are not sure to see what it looks like. If the clutch is engaged .meaning turning, then the ac control panel in the car is bad and needs replacing . The clutch should not be turning with the ac switch in the car in the off position ( no green light).
No
Yes, i can try with some research.
Will get back to you in another day. it's cloudy and dark now. I will look at it when it's sunny.
Old Apr 21, 2020
mustfirst's Avatar
Today I drove the car and it blew cold air all day. Same distance 1.5 hour round trip. So far it only stopped blowing cold air one time after I replaced the relay, that was just 2 days ago.
Old Apr 21, 2020
chuffsy's Avatar
Ok , so next time if it is not blowing cold and if you can safely do so , turn off the ac , open hood and see if compressor turning. If it is turning with the ac switch turnrd off then as I mentioned before the ac panel is bad. Be safe
Old Apr 22, 2020
Super Moderator
When it stops blowing cold air also check if the compressor is running when turned on in the cab. It should be on for ~10 seconds, off for ~10 seconds, then back on. If it isn't I would look at the compressor clutch. Over time the clutch wears increasing the gap. Eventually this gap becomes large enough to cause slippage which overheats the compressor. The compressor thermal protection then turns it off. Once cooled down (may take an hour) the compressor will work again until it begins to overheat. The clutch gap can be adjusted to fix this.
Old Apr 24, 2020
mustfirst's Avatar
Still did not stop blowing cold air since that one time it happened after I replaced the relay.
So far so good.
I will try all the suggestions from everyone if the ac stops working again
Old Apr 25, 2020
chuffsy's Avatar
Awesome and report back if the problem occurs again. Good luck
Old May 6, 2020
mustfirst's Avatar
May 5th
I finished worked and was driving home. But I wanted to grab food and on my way to KFC the AC stopped blowing cold air, after driving for 15 minutes, started to blow cold again again for 5 minutes and then it stopped again. Picked up my KFC and on the rest of the way home it was not blowing cold air.
May 6th
Driving to work had no AC issues. On the way back I did the same trip as yesterday, on the way to KFC the AC started to blow air, not cold. After KFC I drove for 10 minutes on the local road before entering the highway and after 5 minutes on the HWY the AC started to blow cold air again. Very similar to yesterday.
It looks like the AC starts to work when I drive on the HWY.
I checked the compressor it spins only when i press on the MAX AC. It won't spin if I only press the AC or turn the heater on.
Anyone knows what is going on? Does the car need AC refrigerant?
Old May 7, 2020
Super Moderator
Checking the system pressures and the compressor clutch gap have already been suggested. Did you do these yet?
Old May 7, 2020
mustfirst's Avatar
I checked the compressor already. its in the reply above.
Old May 8, 2020
Super Moderator
You checked if the compressor was engaging, you didn't check the gap or the system pressure.
If the pressure is right on the edge of too low the system can shutdown to avoid damaging the compressor. As stated previously if the compressor clutch gap is too large it causes slippage which overheats the pump. The pump has a thermal protection built in so it shuts off until it cools down to avoid damage, could be 15 minutes to an hour. I am 99% sure one of these is your issue.
Old May 8, 2020
mustfirst's Avatar
delete
Old May 8, 2020
mustfirst's Avatar
delete
Old May 8, 2020
mustfirst's Avatar
It looks like the compressor is not engaging. It was the hottest day of the year today. On my way back home the AC suddenly stopped blowing cold air. I pulled over on the hwy and did not shut down the engine. I opened the hood and inspected the compressor and counted until 10 two times but the compressor did not spin at all. It looks like the problem is the compressor.
I also think it doesn't need refrigerant otherwise it would not blow cold air occasionally.
Old May 10, 2020
mustfirst's Avatar
Anyone knows how to fix this? or should i take it to the mechanic?
Old May 11, 2020
Super Moderator
You need a feeler gauge to check the compressor clutch gap. For the clutch gap measure the clearance between the rotor pulley (A) and the armature plate (B) all the way around. Should be between 0.35-0.65 mm (0.014-0.026 in.).
If the gap is too large (which I'm guessing it is) you can remove a shim to put it back in spec. You need a compressor clutch holder tool in order to get the center nut off.
Old May 11, 2020
Colin42's Avatar
If you can't figure out how to do this then take it to a mechanic
Old Jun 3, 2020
mustfirst's Avatar
Mechanic replaced with an used compressor. Cost = $400 CAN, best investment ever because I'm going to do a 7 days road trip.
Old Jun 4, 2020
Super Moderator
Almost certainly didn't require a new compressor but at least it's working.
Old Jun 4, 2020
EarleD's Avatar
EarleD is an unknown quantity at this point
i just did the compressor clutch spacer thing. Super easy. Took about 45 min. AC blowing cold again. Had one spacer took it out. Took longer to tske the wheel well liner out.
thebluecoat
Air Conditioning
May 11, 2020 07:18 AM
fabfive16
May 3, 2015 09:26 PM
roger t
Aug 2, 2014 01:17 PM
breakerfall
Jun 29, 2014 02:43 PM
sixout
Jun 28, 2012 05:45 PM
