Regular Maintenance Post Questions/Information about Regular Maintenance here
DIY Tune Up ?
Old Feb 15, 2024
ES2Spec's Avatar
Yonaka Representative
ES2Spec is an unknown quantity at this point
Cool DIY Tune Up ?
I am planning to refresh the whip soon.
I will being doing timing/water pump, cam seals, valve cover gasket, valve adjustment. brakes, all fluids changed(trans included), etc. [Already did Spark Plugs]
Basically all nine yards almost haha. I am not super informed on the D17A2, are there any additional gaskets or seals I should look into
that have a possibility to leak at a older age besides what I'm already changing?
I will probably change those out as well if there are any.
All information or advice you have on the matter will be greatly appreciated.
I read the DIY Sections in the forum as well, I promise!
[2005 Honda Civic Ex Special Edition] Car just hit 126,000 Miles, I am the second owner so it was a good find for sure.
I am going to give Full Synthetic Quaker State(Read Good Things) a shot this upcoming oil change as well. I'll have that oil sent out for inspection.
I also have a Mr2 and all my buddies do the analysis on theirs and we compare. Highly recommend doing so, fun stuff to nerd out on haha.
If you read up to here, I appreciate you all <3 now go turn some wrenches
Old Feb 16, 2024
BrotatoChip's Avatar
Super Moderator
Re: DIY Tune Up ?
I would say replace the O-ring between the oil pump and block. It's a common cause of oil leaks. But, that would require dropping the oil pan and removing the oil pump while you have the timing belt off.
Old Feb 16, 2024
Re: DIY Tune Up ?
not a DIY article, moving to mechanical issues
xRiCeBoYx
Electronics DIY
Feb 2, 2018 02:07 AM
Kennykid2002
Engine DIY
23
Aug 14, 2013 03:22 PM
TFMEX
Exterior DIY
15
Jul 18, 2012 05:56 AM
Kennykid2002
Jan 22, 2011 02:18 PM
s3recap
20
Jul 9, 2010 01:57 AM
