DIY: Homemade 1-Man Bleeder - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 01-22-2011   #1
Kenny the Ricer
Kennykid2002's Avatar
Need to bleed your brakes and dont have a partner in crime?
No need to fear!!! <insert super hero name here> is here!
Very simple DIY
$0 cost for me, since I had everything laying around the house
Materials:
A Jar, bottle, or can
Some small tubing
A drill (with drill bit)
-Optional
Hot glue gun
Hammer
Nail
Step 1:
Grab a jar, or bottle, or can (preferably clear, so you can see through it)
and some tubing, I used some from a sprinkler system I had, have enough to fit to the bottom of the jar, and about 6" left over
And yes, I got a jar of empty Korean BBQ Sauce....you jelly?
Step 2:
With a drillbit slightly smaller than the tubing size, drill a hole into the top of the cap of the jar/can/bottle, and stick the tube through the hole
(As some of you drillers know, that a hammer and a nail to hammer a pilot hole through might be easier to drill. If you do this, I would hammer a second "breather" hole next to/near the original hole)
OPTIONAL STEP 3:
If you have a Hot glue gun, I would glue the top and bottom of the cap to ensure the tube will not move around.
Step 4:
Make sure everything works. Make sure you have a breather hole on your jar/can/bottle! I totally forgot about that and ended up with brake fluid squirting back at me from the pressure.
Some people like to put a little brake fluid in the bottle before starting, so that no air will go back into the bleeder, but totally up to you. I just used a plastic spoon to scoop some from the resevoir and put it in the jar
Hope that all helps you guys
Have fun.
Kennykid2002 is offline   Reply With Quote
Old 01-22-2011   #2
sl33pyriceboi's Avatar
Re: DIY: Homemade 1-Man Bleeder
ur still letting air in thought ur bleeder valve.
the only true "one man" bleeding job is with a speed bleeder.
sl33pyriceboi is offline   Reply With Quote
Old 01-22-2011   #3
Kenny the Ricer
Not if theres fluid in the tubing (which is when your doing the bleed)
Old 01-22-2011   #4
Trance Addict
MelJ's Avatar
I used a similar setup, although I got a kit from Harbor Freight. Worked the same exact way. I still had someone there, which kinda defeated the purpose, but the bottle had a giant magnet on it. Worked pretty well for bleeding my clutch too. I like this DiY though. So....how's that Korean BBQ sauce taste?
MelJ is offline   Reply With Quote
Old 01-22-2011   #5
Kenny the Ricer
Before or after the bleed?
JK, we were testing this brand of kbbq sauce, it was crap compared to the other one
Old 01-22-2011   #6
Quote:
when u open the bleeder valve, air gets in thu the threads if ur not careful.
but on a side note, it feels great after bleeding huh?
Thread Thread Starter Honda Civic Forum Replies Last Post
My 7th Gen 1 year anniversary bsmiley 7th Generation Civic 3 04-27-2015 02:27 PM
Is this worth buying? streetglower Wheels, Tires & Brakes 0 05-29-2005 03:58 PM
Anyone here Have a One Man Brake Bleeder Kit? streetglower Wheels, Tires & Brakes 0 03-20-2005 08:41 PM
Is this the "bleeder" ? *pic Vinnie Wheels, Tires & Brakes 1 12-30-2004 06:27 AM
Speed Bleeders? 2k2civic Wheels, Tires & Brakes 5 10-30-2004 05:33 PM
Tags
bleeder, bleeding, diy, homade, home, homemade, honda, jar, made, man, power, size, speed, tubing, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2017 CivicForums.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
