Regular Maintenance Post Questions/Information about Regular Maintenance here
Oil filter question
Old May 16, 2020
SynysterDan's Avatar
SynysterDan is an unknown quantity at this point
Oil filter question
Hi there,
Can anyone tell me what size oil filter is needed for an 02 1.4 civic please?
I need to do an oil change but when I looked for filters it had 2 options. A short and stubby version and a longer and slimmer version.
My girlfriend overfilled it by a litre at least by the looks of it so I dont want to drive it.
Can you see the filter without lifting the car at all?
tia
Old May 18, 2020
Wankenstein's Avatar
Re: Oil filter question
Get under the car and measure the oil filter height and circumference. Check measurements against the two options you mentioned.
Old May 23, 2020
Thanks for the reply mate. It was a bit of a tricky one to get at so I took an educated guess instead and it was the correct one so all good.
Old May 23, 2020
mac25's Avatar
Dr Krieger of Modification
Honda filters are standardized unlike inferior domestic pos cars,lol.
before 2001 you can cross reference off of this number,
OF4459 (as in "oscar" "franklin" 4459). About 4" diameter, 4.5" tall.
2000+ is OF4622. About 2.75" diameter, 3" tall.
Threading is the same so either will work. Older cars burnt more, so there filters are bigger; if you use the big one, you'll have to add a bit.
Some aftermarket filters are larger than OEM, which is fine, the threading for basically all hondas/Acura is the same, just check your level, after starting the vehicle, and turning it off again.
Tony1234
Dec 14, 2018 01:48 PM
CivicLxS
20
Jun 5, 2012 08:21 PM
LoKo498
Jul 10, 2005 06:02 PM
LazyDog01
Feb 18, 2004 03:34 PM
slamtank
Jul 20, 2003 01:01 AM
