Regular Maintenance Post Questions/Information about Regular Maintenance here
Best Oil to use
Old Jul 6, 2010
  #31
unTuned's Avatar
Re: Best Oil to use
Originally Posted by nucivicowner
Untuned, (as well as a lot of other poster on here) you need to get educated on fully synthetic oils. I use Amsoil 100% synthetic on my 07' Tundra (5.7 liter, 7 qts.) with over 86,500 miles on it. I go 12 months and approx. 20,000 to 30,000 miles a year before i drain the oil and replace the filter. I also replace the filter and top off the oil to full at 6 months. I have 3 other vehicles in my fleet, a 01 civic ex (1.7 liter) with 130,000 miles, an 03 CR-V (2.4 liter) with 140,000 miles & an 01 Grand Caravan (3.3 liter) with 146,000 miles. They get a filter & drain once a year and filter and top off at 6 months. I use the Amsoil XL synthetic oil in these vehicles. They only average about 10,000 to 15,000 miles a year. I had UOAs done last year for all 4 vehicles and the reports came back ok for all. They did indicate that all vehicle's oil were at the end of there life cycle & recomended draining. When i do the math on oil changes for these vehicles i save money using the synthetic oils. The synthetics, especialy the full synthetics, are way more stable than dino juice.
i should educate myself? these people are asking for advice on how to make a car last. you think what you just said is good advice for someone new to cars? use your oil for 100k miles for all i care. my point is that you should not, and you should be changing it at regular intervals. obviously nothing is going to get damaged overnight, but i guarantee if you keep running your oil for 20-30k or whatever, youll end up buying a new engine. and yeah, obviously the oil was at the 'end of the life cycle'...you think?
keep driving your dodge caravan and going 20-30k between oil changes if you like, nobody cares. when people on here ask for advice, theyre asking because they want whats best for their car and want to know how to make it last a long time. you can be as big a smart *** as you like, but dont ever give anyone the advice that they should be waiting that long between oil changes because thats a load of BS. id love to see what your oil filter and your oil looks like when you drain it after 30k miles.
ignore this guy.
Old Jul 6, 2010
  #32
Crappycivic's Avatar
Crappycivic is an unknown quantity at this point
Re: Best Oil to use
you sir are a joke ,go somewhere
Old Jul 6, 2010
  #33
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Re: Best Oil to use
Originally Posted by IceColdJones
I more just want to know if people use regular oil or synthetic and how often (mileage/months) do they change it.
In the Civic I use Mobil 1 5W-30 with either a Mobil 1 or Purolater Pure One
filter and change it every 5,000 miles.
I am going with 5,000 miles for a couple of reasons. First, this car was purchased with 85,000 miles and no service history. I did an Auto-Rx clean and rinse with dino and now use syn. The syn is still cleaning the engine so I keep the intervals short. The other reason is the car is used for short trips so often the oil does not get hot enough to burn off contaminates and condensation.
Old Jul 6, 2010
  #34
Armith's Avatar
Armith is an unknown quantity at this point
Re: Best Oil to use
[bs_comment]
Try this.. Pick up some Amsoil, and every 10k miles drain your oil into some cheese cloth and let it strain out all the crap into a metal pan.. Make sure it's metal because then you can attach a big magnet to the bottom of the pan to further trap the small metal particles that may have made it thru the cheese cloth.. change the filter and put the oil back.. Top off with new oil if necessary. Afterall that little bit of new oil will freshen everything up. You should be able to get your oil to last for 50k...
[/bs_comment]
OK just an sarcastic attempt at a little humor.. I've actually heard of people doing similar ridiculous methods for filtering and reusing their oil for motorcycles and small commercial machinery.. DO NOT TRY THIS!
In all seriousness.. I use the Walmart 5+ quart jug of mobil 1 5w-20 and new filter every 5000 miles.. Though I'd like to try some extended life stuff.. doing oil changes every 4-6 weeks sucks..
Old Jul 6, 2010
  #35
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
Re: Best Oil to use
why would you ever wait that long... its just dumb... i have seen what builds up inside the engine if you wait to long to change your oil... robbing the engine of performance, gas milage and life of the engine.... i would love to see what your oil looks like when you finally drain it
Old Jul 7, 2010
  #36
Armith's Avatar
Re: Best Oil to use
It best, maybe something like what you'd find on the bottom of the pot that has days old coffee.. At worst more like something you'd see road crews using to fill in cracks in the road.
Who knows, throw in a little prolong with your oil.. You can drive with sand poured into your valve train with that stuff!!!
Old Jul 7, 2010
  #37
Muirsy's Avatar
Re: Best Oil to use
^^ lol
Old Jul 8, 2010
  #38
pjb3's Avatar
Re: Best Oil to use
There are plenty of people that like to use extended oil drain intervals and if done correctly there is no problem. Most people dump their oil long before it is at the end of it's life, by doing analysis during the life of the oil you know exactly where your oil stands rather than guessing. Another advantage to extended drains and doing UOA's is that it can pick up problems in an engine before they become apparent. UOA's can alert you to high numbers in wear metals, silica, antifreeze and other conditions before they damage an engine. I could point out that nucivicowner is basing his maintenance on actual data while those of us that change oil based on intervals are just guessing. Assuming he is adjusting the oil change interval based on the results of the analysis it is pretty much guaranteed that he will not get the dirt, sludge and "tar" that people are suggesting.
I do not recommend extended drain intervals and I do not do them on my cars. I don't recommend them because I believe that it does require a certain level of knowledge and understanding that not everybody has. I usually tell people to follow the manufactures recomendation, you can use the cheapest oil and filter and still be safe.
In my own cars I don't do extended drain intervals because i like getting my hands dirty and it gives me a chance to check other items as well. It also seems to me that it is more cost effective for me to change the oil for $25 to $30 rather than spend $20 on analysis and then change the oil. I may use more oil but from an environmental standpoint, but as long as I recycle my used oil I feel it is about even.
When it comes to oil, everyone has an opinion and in most cases there is no one right answer. Dino versus syn, what weight oil to use, how often to change oil, it really comes down to what works best for you. If you are really interested or want to learn about oil, additives, filters, etc., I would recommend the web site, bobistheoilguy.com.
Old Jul 8, 2010
  #39
Armith's Avatar
Re: Best Oil to use
someone mentioned the UOA!!!! Damn!! Won't be long now before someone will have to clarify Oil Analysis vs Oil Life Monitor..
No the maintenance light not being lit does not automatically mean the oil is fine..
So lets summarize:
Simple answer
-Any Oil Dino or Synthetic @ 5w-20 to 10w-30 or others based on specific environmental and driving conditions is fine.
-manufacturer recommended 3k-4k miles is best. more often if harsher environments and driving conditions.
-extended intervals regardless of oil brand, marketing hype, or fancy oil life monitoring methods is to be "at your own risk"
More complex answer
-How much your drive, how hard you drive, environmental conditions, general maintenance habits, temperature and air quality, your mood... basically everything can vary what is "best"
-If you have the time, knowledge, ambition, and need to get 101% of every last molecule of your oil.. There are a variety of things you can do and oils designed for such use.
-62% of statistics are just numbers.. With the right criteria you could make cat urine seem like the oil additive of the future.. Point is beware of marketing hype and use what works best for you.
Old Jul 8, 2010
  #40
pjb3's Avatar
Re: Best Oil to use
Pretty much true. I would point out that the 3k to 4k is usually the severe schedule so if you change it "more often if harsher environments and driving conditions" you are really getting carried away.
Old Aug 7, 2010
  #41
IceColdJones's Avatar
IceColdJones is an unknown quantity at this point
Re: Best Oil to use
I forgot to ask, how many quarts does my 04 LX take? It didn't come with a manual and the dip stick doesn't have lines on the end of it, just two holes which I'm assuming are for min and max levels?!?!?!?
Old Aug 7, 2010
  #42
Re: Best Oil to use
3.4 quarts for the lx/dx, if I remember correctly.
Old Sep 21, 2020
  #43
Mraks's Avatar
Mraks is an unknown quantity at this point
Re: Best Oil to use
I currently drive with ZEPRO Eco Medalist 0W-20 oil, suitable for old cars.
Old Sep 25, 2020
  #44
Hugertown's Avatar
Hugertown is an unknown quantity at this point
Re: Best Oil to use
It is difficult to say so clearly, because it is really unknown what kind of car you have and so on. Much depends on the age of the car and its other characteristics. So I will say from myself that it is certainly better to address to professionals immediately on this case and read the article about what will be the best oil for honda civic https://carfluidsexpert.com/best-oil-for-honda-civic/ and then you will have a much better chance to pick up the best oil. I will say from myself that at the moment I take Honda Genuine 0W-20 Motor Oil, but here is the thing, you need to look individually at your car and then already make certain conclusions, although the oil that you offered is also very good and fits well. I hope that it helped!
Old Oct 27, 2021
  #45
Davesum15's Avatar
Davesum15 is an unknown quantity at this point
Re: Best Oil to use
I change mine every 3000 with pennzoil 5w30, oil is cheap, engines are expensive
prr
Jun 24, 2016 08:05 AM
CivicLxS
20
Jun 5, 2012 08:21 PM
tred311
Feb 17, 2008 09:02 PM
nova4dr_racer
Oct 22, 2005 09:24 PM
ZSKCivic01
Nov 28, 2004 02:40 AM
