Forced Induction Post Questions/information about Forced Induction here
no o2 sensors or catalytic converter
Old Dec 28, 2019
theeDarkZeus's Avatar
theeDarkZeus is an unknown quantity at this point
need help please If anyoie can shed some light on this please ,
i have a 1998 honda civic vti sohc vtec
so I have no o2 sensors or catalytic converter on my car, im eventually going to install a turbo in it, I was just wondering if anyone knew anything about it
thanks
ive only installed a whale intake , some 4-2-1 epman headers and thats about it, theres also a o2 sensor bung on there but dont what for when there were no o2 sensors on the factory headers
any help would be much appreciated thank you
Old Dec 28, 2019
mac25's Avatar
Dr Krieger of Modification
Re: no o2 sensors or catalytic converter
...not really the best idea to run no upstream o2 sensor, while stock.
This is your a/f sensor (air fuel).
Without it installed the engine runs rich. Which reduces power, and money in your pocket.
The reason people remove the stock a/f on boosted cars, is that they're running aftermarket tuning ecus, with a stand alone, high quality, wideband a/f sensor.
As for the bung hole on your header
If its placed on a single runner, this is where you mount the OEM a/f, if you're running a dual a/f system (usually for a piggyback ecu)
The original bung hole, which is usually below the header collector, is where you run the high quality aftermarket a/f. This is so it can collect data from all four cylinders, regarding the air, fuel mix.
Lordscivic
Mar 26, 2014 07:36 PM
Rockstargarwood
Jan 22, 2014 06:11 PM
BasicEssentials2k1
16
Sep 24, 2003 10:57 PM
asdfasdf
Dec 13, 2002 10:18 PM
IDQcivic
Mar 29, 2002 10:39 AM
