O2 question? Please help
Ok guys I have a 1996 civic ex with a d16y8 motor. The idiot before me put dc headers with some crazy catalytic converter attached to it. Neither of the o2 sensors are hooked up and my car is running like crap. The cat that is on the car doesn't have a hole for the second o2 sensor. My first question is 1. If I hook the o2 sensor before the cat without hooking the second one up will the car start to run better? My next question is 2. For the second sensor can I just drill a hole in the piping after the cat and plug the o2 sensor in that? Or do I have to save up and buy a new cat. Thanks for the help. I'm new to this forum so idk if I'll get an email with the replies but if not my email is rockstargarwood7@gmail.com thx
Re: O2 question? Please help
Welcome.
1) Maybe. Maybe not.
Depends on what the real cause of the running problems are.
If it really runs like poop, disconnected O2 sensors may not be the problem at all.
See what the rest of the CEL codes are, there may be more important things at fault.
2) Any exhaust shop should be capable of welding in a bung to properly fit the O2 sensor.
If the sensors aren't the problem, it won't run better.
If the sensors are indeed the problem, I'd expect you would be able to tell a difference within a minute or two.
A pair of working sensors might reveal more issues/codes indicating other problems (such as too lean or rich, cat code, etc.).
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
