Air Conditioning Post issues with air conditioning here
Screeching sound when heat or ac turned on.
Old Jan 3, 2025
Augustkuhlmann's Avatar
Augustkuhlmann is an unknown quantity at this point
My 2004 Honda civic makes a sound that sounds like a belt slipping, but only when first starting the car, or if the heat or ac fan is on. Does anyone know what could be causing this?
Old Jan 3, 2025
betdriver01's Avatar
betdriver01 is an unknown quantity at this point
Re: Screeching sound when heat or ac turned on.
i had a similar issue couple weeks ago when i finished assembling a cylinder head gasket job. all i did was to check and give the right tension to the belts. so after doing it if sound persist, replace the belt. pulleys will make it all the time not only at the start.
Old Jan 4, 2025
belt tension or old belt
Old Jan 4, 2025
Colin42's Avatar
Something jammed in the blower motor maybe if its not the belts
sdraza1
Air Conditioning
Aug 1, 2024 09:54 AM
Pete6032
Air Conditioning
Jun 5, 2020 03:41 PM
Fuego
Sep 24, 2014 05:40 PM
zen_master
Mar 22, 2004 05:32 PM
