Air Conditioning Post issues with air conditioning here
04 Si(EP3) AC Compressor Replacement [solved]
Old Jul 9, 2023
zoom070's Avatar
zoom070 is an unknown quantity at this point
Hey! I'm trying to replace the ac compressor on my ep3 without dropping the subframe. I've heard it can be done similar to how the alternator is done. That is, up through the passenger headlight by moving back the radiator. However, upon taking everything off, the very last bolt to complete this removal seems to be impossible to remove as it is blocked by the subframe. Again I'm novice so I'm trying to avoid dropping the subframe even a little. Any ideas? I'll attach a image of the bolt and of the bar circled in red if I can figure out how.
Thanks!
The ac compressor bolt pointed to in red
The bar blocking it(subframe?) Highlighted in red.
Old Jul 9, 2023
Colin42's Avatar
re: 04 Si(EP3) AC Compressor Replacement [solved]
Undo an engine mount, raise or lower the engine, and then get the bolt? That's what I would try
Old Jul 9, 2023
zoom070's Avatar
This may be a dumb question but you said "an engine mount". Could I undo a singular corner? I'd probably only need an inch or two. But I'd need a cherry picker for that would I not?
Old Jul 9, 2023
Colin42's Avatar
Whichever mount is closest, probably where the belt and pulleys are. 2x4 and a floor jack under the oil pan.
Old Jul 9, 2023
zoom070's Avatar
Won't damae the engine? I've always assumed the oil pan wouldn't be able to hold the weight of the engine. I suppose it's got the 3 other mounts though in this situation? Thanks by the way!
Old Jul 9, 2023
hondas have sturdy pans.
changing clutch involves jack under engine holding it up
other manufacturers have pans that can get a dent, hondas seem ok
Old Jul 9, 2023
Colin42's Avatar
The 2x4 spreads the weight it will be fine
Old Jul 9, 2023
zoom070's Avatar
So before I try the "lift the engine" idea, I found a YouTube video of someone doing this by completely removing the radiator which gave him access to the bolts from the front looking back. Is there a chance someone here can confirm it's possible this way? I'm unable to try either way until Friday due to some upcoming events this week.
Old Jul 9, 2023
Colin42's Avatar
Then you have to drain the coolant.....
engine mount is a lot simpler.
Old Jul 10, 2023
BrotatoChip's Avatar
Super Moderator
You don't need to fully remove the bolt. Use a wrench or socket to loosen then remove the compressor with the bolt still in the hole.
However, I don't see how it's possible to remove the compressor without dropping the subframe.
Old Jul 10, 2023
zoom070's Avatar
Was able to do it by removing the radiator completely and then was able to access the bolts from the front looking back. I was nervous to drop the subframe or mess with motor mounts because I live in the rust belt and bolts snapping and/or rusting out is extremely common
Old Jul 11, 2023
Super Moderator
You're more likely to break a radiator support bracket bolt than any engine mount or subframe bolt. But I understand what you're saying. I'm in Ohio and deal with rusty and crusty bolts all the time.
Old Jul 11, 2023
Re: 04 Si(EP3) AC Compressor Replacement [solved]
I thought on saying that too...
F22C4me
Air Conditioning
Oct 8, 2021 01:41 PM
glene
Air Conditioning
Jun 17, 2021 02:35 PM
sean_incali
Apr 17, 2021 07:28 AM
Grimlock
40
Jun 19, 2015 08:25 PM
gudoffer
Aug 12, 2009 09:35 AM
