Air Conditioning Post issues with air conditioning here
2003 Civic Ex ac
Old Jun 26, 2023
Jordan.Sleeper's Avatar
Jordan.Sleeper is an unknown quantity at this point
2003 Civic Ex ac
Ac compressor wont run unless jumped at the fuse box.
Old Jun 26, 2023
BrotatoChip's Avatar
Super Moderator
Re: 2003 Civic Ex ac
So figure out why. Low refrigerant? Failing relay or fuse? Failing HVAC controls?
Old Jun 26, 2023
Colin42's Avatar
Yep need to do some proper diag
Old Jun 26, 2023
All relays and fuses are good. System is good on refrigerant
Tested pressure switch its good as well
Old Jun 27, 2023
Super Moderator
What pressure did you read, high and low side?
Old Jun 27, 2023
low side
Old Jun 27, 2023
Colin42's Avatar
Need both sides, and actual psi numbers
Old Jun 27, 2023
can i check highside with one of those gauges that come on the refills u can buy?
Old Jun 27, 2023
Super Moderator
Not likely. At a minimum you need to check the low pressure side. Should be enough to know if there's enough refrigerant, but not enough to now if the system is working properly.
Old Jun 27, 2023
the low side is at 50psi
Old Jun 27, 2023
Colin42's Avatar
You can get a set of the proper gauges on amazon for pretty cheap
Old Jun 28, 2023
anything else i can try before i spend unnecessary money?
Old Jun 28, 2023
Super Moderator
At 50 psi, what's the outside temperature? Compressor should not be running when you check. You'll have to remove your jumper or check when the engine is off.
Old Jun 28, 2023
im going to check the psi again and the temp again
Old Jun 28, 2023
Super Moderator
Pressure should roughly match ambient temperature. If it's 50F outside, pressure should be around 50 psi.
Old Jun 28, 2023
its at just about 50psi at 80 degrees😬
Old Jun 28, 2023
should i charge it more?
Old Jun 28, 2023
Super Moderator
That is low but the minimum to turn on the compressor is like 28 psi.
Old Jun 28, 2023
Any other reasons why its not kicking on?
Old Jun 28, 2023
Super Moderator
See previous replies.
310civicEX
16
Feb 2, 2018 11:26 PM
lawnmowing
Jul 18, 2009 06:45 AM
WEAPON-R CIVIC
Jul 28, 2008 09:15 PM
DaMadScientist
Jan 17, 2007 05:48 PM
EM2Civic
Jun 13, 2004 07:59 PM
