Air Conditioning Post issues with air conditioning here
2002 EX A/C compressor clutch [solved]
Old Sep 24, 2021
F22C4me's Avatar
F22C4me is an unknown quantity at this point
Hi All,
Seeing if its possible to change out the A/C clutch with the compressor still hooked up in the car. Anyone done it? I need to change it due to the noise coming from it and visual inspection revealing the pulley "wobbling".
Old Sep 25, 2021
Wankenstein's Avatar
re: 2002 EX A/C compressor clutch [solved]
Originally Posted by F22C4me
Hi All,
I've change the clutch and coil without removing the compressor on a 6th gen but not on a 7th gen. If, there is room to do it then it should be possible.
Old Sep 27, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
I've always liked this video on removing a shim on the compressor shaft to repair my A/C for cheap when the clutch wasn't engaging. It will show how to access and replace the clutch without removing compressor from car. Skip to about 14 minutes in the video...
Old Oct 8, 2021
F22C4me's Avatar
Re: 2002 EX A/C compressor clutch [solved]
Yes it was possible to replace the clutch without moving the compressor. Thanks for the support on this.
Now the clutch will not engage. I suppose it has to do with the original shim being worn?
THANKS,
Chuck
glene
Air Conditioning
Jun 17, 2021 02:35 PM
sean_incali
Apr 17, 2021 07:28 AM
Suraj Khellawan
Aug 29, 2017 08:50 PM
Grimlock
40
Jun 19, 2015 08:25 PM
gudoffer
Aug 12, 2009 09:35 AM
