Air Conditioning Post issues with air conditioning here
AC Compressor Seized--AARRGGG!
Old Aug 11, 2021
rileysowner's Avatar
rileysowner is an unknown quantity at this point
This is more of a vent than anything. Last night on my way home from work the AC Compressor seized up with the clutch locked and burned off the belt. Why the Honda engineers thought having the AC compressor and the alternator share the same belt was a good idea, I guess I will never know. I am just happy I was close to home and not closer to work as I don't know if I could have made it back on only battery power. Anyway, my plan at this point is to bypass the AC using a belt for the same year Civic that did not include AC. Googling showed that as the way to bypass the compressor.
Annoyingly, no one has the belt in stock, so I cannot get it fixed today. Thankfully, we have a second vehicle that I can get to work in, but the work I was doing on it has to wait.
Old Aug 11, 2021
BrotatoChip's Avatar
Super Moderator
Re: AC Compressor Seized--AARRGGG!
Newer Civics have one belt that runs everything, including the water pump. Consider yourself lucky
Old Aug 11, 2021
That seems to be the way they are going in the automotive industry in general. On my 2005 Chevy truck, everything but the AC compressor is on the main serpentine belt, the AC has a dedicated belt. I thought that was a great design. The 1997 Van I used to have had only one belt, and when the AC compressor seized the truck was basically dead. I had just gotten a truck to replace it, so it wasn't a big deal except for seeing how bad an idea having the AC compressor on the vehicle with everything else is. I would have hoped Honda would have done a better job in the later generations. Even the way the belt system is set up with having to unbolt the power steering reservoir and remove the power steering pump belt to replace the mission-critical belt to the alternator seems like a backward design. I am thankful that I don't have one belt as I can easily bypass the ac compressor until I have time to get a new one installed.
Old Aug 11, 2021
Takato's Avatar
Takato is an unknown quantity at this point
Other civics have multiple belts? I have a hybrid of the same vintage ('03) and it uses one belt for the water pump and AC compressor. Maybe because it doesn't have hydraulic power steering or a typical alternator? I've seen my fair share of normal civics in the junkyard, but I've never noticed that they have multiple belts. Anyways, best of luck on fixing your civic!
Old Aug 11, 2021
Mine does, outside one for the power steering only I think, and the inner one for the alternator, AC compressor. Design-wise, having the power steering and compressor on the same belt makes much more sense in my mind as I can keep driving with that belt broken. I can't really keep driving without an alternator.
Old Aug 11, 2021
temp fix:
Originally Posted by ezone
Ask for a belt to fit a DX without AC.
https://www.civicforums.com/forums/3...ss-solved.html
Old Aug 11, 2021
Originally Posted by sdaidoji
That is what I have done.
Old Aug 11, 2021
sorry, it seem that I can't read well you said that in first post...
Old Aug 12, 2021
Well, one of the downsides of having used vehicles is how people have "fixed" things in the past. Apparently, one of the previous owners or their mechanics decided that the tensioning system is not needed for the power steering pump or the alternator. Getting things loose was the expected challenge, but getting them back together and the belts tensioned is a bigger challenge especially with the pivot point of the alternator being at the top, so I cannot just use a prybar, at least not easily. At least the belt for a Civic without an alternator fits.
Old Aug 12, 2021
car-part.com for nearby scrapyards, yank one off
Old Aug 12, 2021
Finding a way to use a prybar to tension the alternator proved easier that I expected. The power steering pump, on the other hand, was more of a challenge. While I really don't like the tensioning system in the 2005 Civic with its stupid wing-bolts, at least with it, I would have been done quicker. At least bypassing the AC compressor with a belt for a Civic without AC worked. Now I have to decide if I want to spend the money on a new compressor and probably a new condenser as well since I am guessing that pieces have broken off inside the compressor and some have already made their way to the condenser. Not replacing it would just mean having them work their way through the system and destroy the new compresser.
Old Aug 12, 2021
Super Moderator
Believe me, nobody likes that.
2k3civicgyrl
Air Conditioning
52
Jun 1, 2023 12:03 PM
pettit1426
Air Conditioning
Sep 29, 2021 11:06 AM
Makadesoye
Interior
Jan 10, 2019 07:59 AM
DanS
Jan 25, 2012 06:19 PM
drjay9051
15
Oct 1, 2010 11:25 PM
