Air Conditioning Post issues with air conditioning here
AC bypass? [solved]
Old Oct 16, 2013
IZZY13's Avatar
IZZY13 is an unknown quantity at this point
AC bypass? [solved]
My AC pump clutch is about to go. Is there a belt that I can get, that just goes from the crank pulley to my alternator? I want to fix my AC, just not right now.
Top Answer
Oct 20, 2013
ezone
Re: AC bypass?
Will the DX civic belt fit with the compressor still in place?
If you draw a straight line from the bottom of the crank pulley to the bottom of the alternator pulley, you will see plenty of clearance away from the top of the AC compressor pulley. Yes it should fit.
Will I still have heat for the defrost?
Heating has nothing to do with the AC.
A DX does not have AC, and it still has heat.
OTOH the defrost function (it's really deFOG, not defrost) won't be as efficient because of the lack of AC to remove humidity from the air.
But a DX doesn't have AC.
And do i need to pull the relay for the AC?
Does the AC work now? Why are you doing this with the belt?
Yes, I would pull out the relay for the AC clutch.
Old Oct 16, 2013
GolNat's Avatar
Prelude Owner
Re: AC bypass?
You can take the belt that is on there and pinch it at one end to measure the size belt you will need. Take the pinched belt to the parts store and find a belt that is close to that size.
You can also order one here:
http://www.corsportusa.com/store/cat...ducts_id=15246
Old Oct 16, 2013
Re: AC bypass?
Ask for a belt to fit a DX without AC.
Old Oct 16, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: AC bypass?
^Exactly. Civic DX has no air conditioning so the belt is a perfect fit for what your looking for. Are you 100% sure it's the AC clutch? There is a shim in there that needs to come out if the clutch stops making contact. If you remove the shim the compressor clutch might start functioning properly again.
Old Oct 16, 2013
IZZY13's Avatar
Re: AC bypass?
Thanks guys! I'm pretty sure it's the clutch. I'ts been making some bad growling noise! I took the belt off & gave it a spin & it sounds like the barrings are going out.
Old Oct 16, 2013
Re: AC bypass?
Sounds like the bearing for the pulley is probably shot.
Old Oct 16, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: AC bypass?
Ok just thought I'd throw that out there. I wonder how many people replace the clutch when they only needed to pull out the shim
Old Oct 16, 2013
Re: AC bypass?
There's an actual spec for that.
Old Oct 16, 2013
IZZY13's Avatar
Re: AC bypass?
Thank you again guys!
Old Oct 16, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: AC bypass?
How many Joe Schmoe mechanics know that?
Old Oct 20, 2013
grunt's Avatar
grunt is an unknown quantity at this point
Re: AC bypass?
Hello, I understand about bypassing the ac compressor with a alternator belt from a DX civic without AC. Will the DX civic belt fit with the compressor still in place? Will I still have heat for the defrost? And do i need to pull the relay for the AC? I have 2001 LX civic. Any info would be appreciated...
Old Oct 20, 2013
mikey1's Avatar
Re: AC bypass?
yes the belt will fit with the compressor still in place
yes you will still have heat,
you can pull the relay if you want but not nessessary
Old Oct 20, 2013
Re: AC bypass?
Old Oct 20, 2013
grunt's Avatar
Re: AC bypass?
My AC compressor on my LX is bad. Winter is right around the corner here and money is tight. I plan on fixing it this spring
Old Oct 20, 2013
grunt's Avatar
Re: AC bypass?
Which is the relay for the AC clutch???
Old Oct 20, 2013
Re: AC bypass?
Look at the diagram on the fusebox lid. Clutch is marked with a picture of a simple plain snowflake.
Top row, 2nd from left?
BRB, I gotta look now
Old Oct 20, 2013
Re: AC bypass?
Yup, that's it. I said the same thing in the past https://www.civicforums.com/forums/3...ml#post4608485
Funny, you have the exact same pic.
Old Oct 20, 2013
grunt's Avatar
Re: AC bypass?
Ok guys. I want to thank everyone who replied to my questions. The DX belt is in and the relay is pulled. Nice not to hear that noisy AC pump. In the future I will be reading up on the AC units. THANKS AGAIN!!!!
Old Aug 11, 2019
Tsao David's Avatar
Tsao David is an unknown quantity at this point
Thumbs up Re: AC bypass?
I was able to fix my daughter's car with this thread, thank you all.
Old Nov 13, 2019
David Darling's Avatar
David Darling is an unknown quantity at this point
Re: AC bypass?
Anybody know if the Dx belt would work on a 2004 Honda civic hybrid. My ac compressor pulley is locked up and trying to find a quick solution until I'm able to replace it
Old Nov 15, 2019
Re: AC bypass?
No. The engine in the hybrid is completely different from the 1.7 in the regular civics.
I think there's a thread or two here somewhere dealing with bypassing the ac comp on one of those hybrids though. Search for it?
Old Apr 30, 2020
Molecule's Avatar
Molecule is an unknown quantity at this point
Re: AC bypass?
This site has saved me twice. AC compressor seized up. I could see it was glowing red when I stopped. Went fishing and then slept in the car all night while it was snowing out. Went the next day to an auto parts store. The closest DX belt was 2 hours away. Some guy delivered it to me and I fixed the car in Culver's parking lot. Eventually got it replaced. Same thing happened 2 years later. I am done with AC. Thanks guys!
Old May 1, 2020
Re: AC bypass?
Glad to hear you've gotten some great help from what's been posted here. I must say, I wish I could say I was done with AC. It's pretty much a requirement here in Vegas. lol
Old May 1, 2020
BrotatoChip's Avatar
Super Moderator
Re: AC bypass?
I went one summer without A/C here in Ohio, that was enough for me.
Old Mar 7, 2021
Curtis Johnson's Avatar
Curtis Johnson is an unknown quantity at this point
Re: AC bypass?
The Honda shop manual has that spec. at 20 thousands.
Csaskins
Air Conditioning
Feb 25, 2019 11:53 AM
kkiley
Feb 19, 2017 02:16 PM
Moparboi
Air Conditioning
Jun 26, 2013 05:36 PM
jewlz
Air Conditioning
Dec 9, 2012 04:13 PM
03civicdx_420
Jul 10, 2007 03:25 PM
