Air Conditioning Post issues with air conditioning here
AC/Heat Vent Issue
Old May 12, 2019
Shannon22's Avatar
Shannon22 is an unknown quantity at this point
AC/Heat Vent Issue
AC and heat works intermittently. Air only leaks out of vents when not working but air is cold or hot depending on if Ac or Heat is selected. Sounds like a blower motor issue but blower motor works 100% of the time - can see it turning when I look behind dash and take out cabin filter. Blower motor speed also corresponds with turning **** up or down so don’t think it is a resistor issue. Looked at 3 of the flap actuators and all move when I press the corresponding buttons on the dash (e.g. I can see mode control flap actuator moving when I change selection from floor to face vents, etc.) recirculation flap actuator also works as well as blend. Any ideas what this could be?
Old May 12, 2019
Shannon22's Avatar
Heat/Ac Vent issue
AC and heat works intermittently. Air only leaks out of vents when not working but air is cold or hot depending on if Ac or Heat is selected. Sounds like a blower motor issue but blower motor works 100% of the time - can see it turning when I look behind dash and take out cabin filter. Blower motor speed also corresponds with turning **** up or down so don’t think it is a resistor issue. Looked at 3 of the flap actuators and all move when I press the corresponding buttons on the dash (e.g. I can see mode control flap actuator moving when I change selection from floor to face vents, etc.) recirculation flap actuator also works as well as blend. Ran HVAC self diagnostic and no problems there. Any ideas what this could be?
Old May 13, 2019
Re: AC/Heat Vent Issue
Post year/make/model/trim
Has the fan been replaced with aftermarket, and someone wired it backwards?
If it spins backwards it can make the usual noise without moving much air
Old May 14, 2019
Shannon22's Avatar
2010 Honda Civic lx. Will check that, but that wouldn’t make it work intermittently would it?
Old May 15, 2019
Your description of the problem and symptom is quite vague.
Do you have a fan issue?
Do you have a compressor issue?
Do you have a heat issue?
Do you have a control or flap issue?
Funkytrunkz
Air Conditioning
Feb 26, 2019 06:18 PM
danielrs
15
Apr 23, 2018 03:46 PM
jroy3221
Feb 6, 2015 09:10 AM
envyminnesota
Mar 9, 2014 09:53 PM
Jeepin1995
Aug 2, 2013 07:54 PM
